Been running this config for months, stable at 9+ hours of prime95 (probably more if I had the time). Yet when I only turned off HT and tried to reboot it wouldn't reach POST but turn off after 3-4 secs and do this in a continuous loop. Typical behaviour of an undervolted cpu but shouldn't turning off HT rather reduce the power needed rather than increase it, or is the problem elsewere? Thanks on beforehand!.
Never had this one but dit you try an bios update?
This will be the most common fix i think.
I did consider it but couldn't be arsed but as I see no other suggestions I don't have much of a choice, being away in another city for work I'll try this when I get home in the weekend. Thanks mate, any more input is most welcome.
If u can't update the bios there ar stil some options open it depends on what u have tried to update it.
Tell me the name of the computer if prebuild.
If it is a computer that you made yourself i need your motherboard name.
Ill hear it when u have the time.
Oke i found the board but i also see there are some bios updates and difrent revisions.
Download bios update's only for your revision.
Find revision treu dowloading cpuz run it and press mainboard tab and look for rev.
rGA-EX58-UD3R (rev. 1.1)
BIOSDownloadVersionDateDescriptionhttp://www.gigabyte.com.tw/Support/Motherboard/BIOS_DownloadFile.aspx?FileType=BIOS&FileID=15691 Download from ...F112010/03/12- Enhanced memory compatibility
- Support new SPI flash type: MXIC 25L1606E
- Enhanced Memory capability
- Support Intel Core i7 6 core processors
- Update new CPU microcode
- Support nVidia SLI
- Improve VGA card compatibility
- Improve S3 resume compatibility
- Intel®Core™ i7 processor D-0 stepping support.
- Enhance DDR compatibility
- Enhance system stability
GA-EX58-UD3R (rev. 1.6)
BIOSDownloadVersionDateDescriptionhttp://www.gigabyte.com.tw/Support/Motherboard/BIOS_DownloadFile.aspx?FileType=BIOS&FileID=15699 Download from ...FI2010/03/12- Enhanced memory compatibility
Shouldn't just installing the latest bios be enough as the latest (should) contain all the newest updates also the ones from previous versions, as with any drivers? flashing anew for each new version will be a pain (and probably unnessecary).
I updated my bios to the newest now and I'm now able to turn off HT without it crashing down. Thanks for the help.
