Processors
14915 Discussions
I have Intel(R) i7-4770K CPU: 4 of 8 Cores are parked: Why
MHutc1
I have a new computer... Could someone enlighten me... why would 4 of the available 8 cores be 'Parked'?
MHutc1
Thanks for your timely answer...
The info at the link you provided seems to indicate the cores don't get parked unless a 'balanced' power plan is in effect. If a 'non-balanced' plan is in place... by default, do they still 'park' if they are not used? In my case Process power management is set as follows: Minimum processor state = 100%, System cooling policy = 'Active', Maximum processor state = 100%... 4 of the 8 cores are parked seemingly whether I am driving the processor hard or not.
Do you have a Processor Utility I might download that would be able to push / stress the cores such that the System would allow all of them to be used?
Silvia_L_Intel1
Yes, we do have a utility for that purpose. The name of it is Processor Diagnostics Tool . Please access the following site and download the version based on the Operating System you have installed. https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=Processor%20Diagnostics%20Tool https://downloadcenter.intel.com/SearchResult.aspx?lang=eng&keyword=Processor%20Diagnostics%20Tool
