16805 Discussions
I have i7-4770 but what graphics card should I use
YAtwa
Hey Intel support
So I have already i7-4700(not k) but my motherboard broke( lga1150)
And I bought i7-8700k with (Lga1151motherboard)
But I was thinking if I return the new Intel and use the old one only need to buy used motherboard ba
Cause there's no in market any more
But I want to run best graphics card in market and its Rtx 2080
So can old Intel run it and if not what is the recommended graphics card should I buy
Please answer me
AlHill
The intel graphics are integrated in the processor. There is nothing to return.
Doc
YAtwa
Did u read what did I say ?
AlHill
Ok, you want to get a new motherboard that runs your old processor, correct? And, you want this new board has to run yournew amd graphics card, correct?
First step is to find a board that has socket 1150, and whose BIOS support the i7-4770.
Then, make sure the board supports PCIe x16 3.0
Doc
YAtwa
Al hill sorry but I think u didn't understand me ,sorry for my English am trying to say that I have old Intel i7 4th gen and trying to ask support if I can use Nvidia Rtx 2080 on my PC
650 W power supply
16g of ram
With i7 4770 prosessor
AlHill
If your new board (and its bios) supports the i7-4770, and if the board supports PCIe x16 3.0,, and if your new graphics card is compatible with the new motherboard, then you will likely have no problems. There are a lot of "ifs" in here.
Doc
Leon_Merts
New Contributor II
FYI
If it helps, I am running a GTX1080 on a 4th gen (https://ark.intel.com/products/77779/Intel-Core-i7-4960X-Processor-Extreme-Edition-15M-Cache-up-to-4-00-GHz- Intel® Core™ i7-4960X Processor Extreme Edition (15M Cache, up to 4.00 GHz) Product Specifications) Intel without problems and have been running the same card in an older system running a Pentium from 2006 (https://ark.intel.com/products/27615/Intel-Pentium-Processor-Extreme-Edition-965-4M-Cache-3-73-GHz-1066-MHz-FSB- Intel® Pentium® Processor Extreme Edition 965 (4M Cache, 3.73 GHz, 1066 MHz FSB) Product Specifications )
YAtwa
Leon
I hope I can understand but I will try to use the old i7 4th gen with the new Rtx 2080
And I will wait for the problem
Leon_Merts
New Contributor II
Hi Yes_R,
Just make sure you check all the specifications when searching for / buying a mainboard for the 4th gen i7.
Like Al Hill mentioned make sure the CPU is supported and preferably that the PCI Express slot is 3.0 (It will work on 2.0 / 1.0 but slower).
Leon Merts
Leon_Merts
New Contributor II
Hi Yes_R,
Both the i7-4700 and the i7-8700K support the PCI Express 3.0, providing the same bandwidth of the PCI Express slot to your video card.
Mostly the memory (DDR3 -> DDR4) and CPU (https://ark.intel.com/compare/75122,126684 Intel® Product Specification Comparison ) will make a difference.
Leon Merts
YAtwa
So I can use the Nvidia Rtx 2080 on Old Intel i7 4770
I only need it for 1080p in next 4-6years I hope so
AlHill
I cannot guarantee the card's compatibility. That will be your challenge.
Doc
