I have a laptop with Intel Core i7 2630QM , at first it working normal but in recent days it have some problem .
Firstly the CPU are working with low performance , so i tested it with CINEBENCH and result is 1,41 pts for CPU and 11,49 fps for OpenGL , this was bad .
You can see http://i1221.photobucket.com/albums/dd475/nguyenductin/cats3.jpg here
Secondly , my Intel Turbo Boost does not working , exactly the column of clock never jump up and down even when i play game , do heavy work ,..
It look like http://i1221.photobucket.com/albums/dd475/nguyenductin/cats6.jpg here . Previously it still runs good
Finally , the fan of CPU is run max speed without the control every time the power on , it nerver stop until power off .
I need a help for my CPU , sometime it make me trouble.
Since this is a laptop system, I would suggest installing the latest BIOS version for your laptop, and if that does not solve the issue, then I would suggest contacting the laptop manufacturer for support on this product.
Keep in mind that we manufacture the processor, but not the cooling solution on a laptop system, and since it is a laptop system, the BIOS is also developed by the laptop manufacturer.
Performing a clean installation of the operating system would be a good idea, but you still need to contact the laptop manufacturer for assistance on performing this step.
![](/skins/images/9701FEC4E90D143B667C09F3DB2F340F/responsive_peak/images/icon_anonymous_message.png)
