Dear Sir or Madam, I need please help: I would installa memory server for my Xeon E5-2665, In my Modo there is a normal memory list only (no ECC no REG).
Please, may ask you to get it...? (if is important, the MoBo is X79extreme6.)
Thank you in advance,
lavorazioni
Hello lavorazioni,
Thank you for contacting Intel Customer Support.
As per the memory specifications of the Intel® Xeon® Processor E5-2665, the processor will support DDR3 800/1066/1333/1600 memory, and also it will support ECC memory. You can check all the specifications at this link:
We do not have a list of tested memory for our processors since this will depend on the motherboard manufacturer.
We do recommend you to check the list of tested memory for the X79 Extreme 6 here:
https://www.asrock.com/mb/Intel/X79%20Extreme6/index.asp#Memory
Sergio S.
Hello lavorazioni,
I am following your case in regards to your Intel® Xeon® Processor E5-2665 and we would like to know if you need further assistance or if you were able to get touch with your board manufacturer.
Sergio S.
Hello lavorazioni,
I am following your case in regards to your Intel® Xeon® Processor E5-2665 and we would like to know if you need further assistance.
Sergio S.
Hello lavorazioni,
We just want to let you know that we are going to close this thread.
As we mentioned on our a previous post, as per the memory specifications of the Intel® Xeon® Processor E5-2665, the processor will support DDR3 800/1066/1333/1600 memory. And we do not have a list of tested memory for our processors.
And we do recommend you to check the list of tested memory for the X79 Extreme 6 here:
Sergio S.
