- Отметить как новое
- Закладка
- Подписаться
- Отключить
- Подписка на RSS-канал
- Выделить
- Печать
- Сообщить о недопустимом содержимом
My i7 6700k works perfectly fine after re installing it. The motherboard I use is a standard Hp omen X motherboard.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Here are a couple of articles that present options, reviews and opinions:
- PremiumBuilds.com: Best Motherboards for i9-9900K Builds
- WindowsCentral.com: Best Motherboards for Intel Core i9-9900K in 2020
- Appuals.com: 5 Best Gaming Motherboards for Intel Core i9-9900K
- Levvvel.com: Best Motherboard for i9-9900K
- EasyPCMod.com: 11 Best Motherboards for i9-9900K in 2020
- PCPartPicker.com: i9-9900K Compatible Motherboards
- Amazon.com: i9-9900k Motherboards: Top Selected Products and Reviews
The best motherboards will have the Z390 chipset. I would go with one of those even if you are not going to attempt any overclocking. If you are on a budget, choose a motherboard with the H370 chipset and avoid any with the B365 chipset (I am not a lover of the B chipsets). Even though some are compatible, I would not use any motherboard with an older generation chipset.
Ссылка скопирована
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Not only does the new processor require a new motherboard, it will also require new DDR4 memory.
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Thanks, any recommendations on a good motherboard that fits the criteria?
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
- Закладка
- Подписаться
- Отключить
- Выделить
- Печать
Thanks so much for the help, I was thinking of this motherboard. MSI MPG Z390M GAMING EDGE AC Motherboard mATX, LGA1151, DDR4, LAN, 802.11AC WIFI, USB 3.1 Gen2, Type-C, M.2, RGB Mystic Light, HDMI, Display Port, Intel 8th and 9th Gen https://www.amazon.co.uk/dp/B07HSBF397/ref=cm_sw_r_cp_api_i_WxhWEbJEGXC50.
Im pretty sure this would work although I am kind of a beginner at this. Thanks again
- Отметить тему как новую
- Отметить тему как прочитанную
- Выполнить отслеживание данной Тема для текущего пользователя
- Закладка
- Подписаться
- Страница в формате печати
