Iam from India,I have to purchase an i5 14600 non k varient, local stores and online retailers doesn't have stocks for those,if it is a tray CPU how do I buy that?
In some locations the i5 14600 non K variant seems to have a much more restricted distribution than other 14th Gen i5 processors. In the UK for example it can only be purchased from a limited number of sources (see graphic below)
Part of the issue may be that it is quite close in price to the 14600K/KF. If no local source is available you might need to consider an alternative such as the i5 14500.
Thanks Brother,I chose this because of the power limitations of my motherboard and it's performance. As you said it may face restrictions in India, anyway I will continue my enquiries otherwise I will decide to switch to 14500.
