I bought a MSI laptop that DDR4 8GB "3200MHz" (PC4-25600) built in.
But it's CPU is I5-10030H that supports "DDR4-2933" memory.
In this case, what should I do?
Just using my memory at 2933MHz?
Or... can I make this CPU to support 3200MHz memory?
Or..... "2933" at "memory support" were not meant MHz at first?
oh or is minimum support DDR4-2666MHz?
Hello @Greden
We hope that the information provided by the community has been helpful to clarify your concern. Since the thread has been marked as "Solved" we will proceed to close this inquiry now from our end. Communications with community peers may continue, but if you need any additional information from Intel, please submit a new question as this thread will no longer being monitored.
Andrew G.
