16774 Discussions
I5 10300H overheating upto 100°c
Kailan
My New Gaming Laptop Temperature Exceeds Over 90°C while gaming Sometimes Reached 100°C Ofcourse It Is Not Healthy Temperature For CPU But When I Checked Google It Said That 10300h Processor Supports Temperature Over 90°C So It Is Not Overheating It Is Running Normal.You Can Check It Too By Searching i5 10300h Normal Temperature On Google
Now My Question Should I Be worried About Temperature Exceeding Over 90°C Or Continue To Play With over 90°C Without Any Actions
IsaacQ_Intel
Hello @Kailan
While certain processors can handle higher temperatures, it's ideal to keep your CPU below 90°C for best performance and durability. Even if the i5 10300h can technically endure higher temperatures, consistently running your gaming laptop at such levels could lead to a shorter lifespan and potential instability.
Although you found information suggesting the processor's tolerance, remember that cooler laptop temperatures generally provide a better experience. Consider these steps:
Overheating Symptoms and Troubleshooting for Intel® Boxed Processors
·        Ensure Adequate Ventilation: Keep airflow unobstructed for proper heat dissipation.
·        Utilize a Cooling Pad: Enhance heat dissipation by using a cooling pad beneath your laptop.
·        Regularly Clean Internals: Remove dust and debris that can block airflow and raise temperatures.
·        Reapply Thermal Paste: Reapply thermal paste if comfortable; it degrades over time and affects heat transfer.
·        Adjust In-Game Settings: Lowering graphics settings reduces strain on the CPU and GPU, curbing heat during gaming.
In summary, while the processor might handle high temperatures, it's wise to keep them below 90°C for long-term health. Employ strategies like cooling pads, cleaning, and adjusting settings to maintain safer temperatures.
Isaac Q.
Kailan
Then 80-85°C Is Healthy For Laptop's Lifespan And Performance?
n_scott_pearson
If, under heavy load, you are seeing temperatures stay below 90c (except for very short duration spikes above 90c - but not to 100c), then yes, you should look forward to the processor lasting to or beyond the normal warranted lifetime.
Kailan
Ok I took your advice and changed therminal paste cleaned my laptop now my laptop temperature ranges 75-85°c how much life span i can expect?
IsaacQ_Intel
Hello @Kailan and @n_scott_pearson
Thank you for your reply.
While we can't predict your laptop's exact lifespan, temperatures of 75-85°C during heavy tasks are acceptable. Cleaning and changing thermal paste enhance efficiency and longevity. Factors like component quality, maintenance, and usage also matter. Regular cleaning, ventilation, and avoiding extremes extend laptop life. No definite timeframe, but proper care should ensure reasonable longevity.
Isaac Q.
Kailan
IsaacQ_Intel
Hello @Kailan.
You're very welcome! Assisting you in resolving this issue brings me great pleasure. I'd also like to extend my gratitude to our wonderful community members who continuously contribute to improving this platform.
It appears that the problem has been successfully addressed. Could you kindly let us know if you would like to close this thread? Should you have any further concerns, please don't hesitate to inform us.
Isaac Q.
IsaacQ_Intel
Hello @Kailan
Since the thread is now solved, we will close it. If you need any additional information, please submit a new question as this thread will no longer be monitored.
Isaac Q.
ForgedCore8
Having a similar issue. Running the same processor as OP. under load it hovers around 92C, and idle it tends to be in the 62-81 range
