I gave had my i5 7600 for about a year now and I can never get the boost clock to go above 3.68 ghz. From what I understand with all Cores utilised it should be able to boost to about 3.9ghz. When I upgraded to my i5 my previous processor was an i3. i flashed the bios and just used the default bios getting. I am using the default cooler that came with the cpu and its temp is usually between 40 and 50 degrees.
Anyone know how I can get it to boost higher?
Hello RicCaw,
Thank you for joining this Community.
I understand that you want to boost the Clock Frequency of your Intel® Core™ i5-7600 Processor.
In order for me to assist you better, please provide me with the .txt file that the System Support Utility will generate. To attach a file, you must click the "Attach" option on the bottom right-hand corner of the response box.
https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows- https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
As well, please make sure that Turbo Boost is enabled on the BIOS of your machine.
In addition, please go ahead and run a stress test with our Download Intel® Processor Diagnostic Tool found here:
https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool
I hope to hear from you soon.
Best regards.
Diego S.
Hello RicCaw,
We just wanted to double check if you still need further assistance.
Please do not hesitate on contacting us back.
Diego S.
![](/skins/images/872293744008A34B36F8ABF94A46CC66/responsive_peak/images/icon_anonymous_message.png)
