Processors
15740 Discussions
[I7-6700K] 4th core damaged?
RBeck2
Hallo zusammen,
ich habe seit einiger Zeit das Problem, dass bei mir sowohl Firefox als auch Chrome ständig abstürzen. Microsoft Edge läuft ziemlich stabil.
Was aber sehr störend ist, dass die Grafik in Spielen zittert, siehe Video, mit iGPU das gleiche Problem.
https://www.youtube.com/watch?v=0QEy9Y4cJZg CPU Kern defekt? - YouTube
Anbei noch ein Screenshot vom Intel Diagnostic Tool
Wenn ich im Bios die CPU nur auf 3 Kerne einstelle, dann laufen alle Browser stabil und in Spielen habe ich keine Darstellungsfehler
Mein PC:
Intel Core i7 6700K
GeForce® GTX 1050 Ti OC 4G
Kühler: Thermalright HR-02 Macho Rev. B
G.Skill RipJaws V DDR4-3200 2x8192mb
Asus Z170 Pro Gaming Bios Ver. 3805
Samsung SSD 850 Evo 250gb
2x 1000GB Seagate Desktop HDD ST1000DM003
be quiet! Straight Power 10 400 Watt
Tower: Fractal Define R5
CPU wurde Anfang 2016 gekauft
Hello, RaBe83. Thank you very much for contacting the Intel Communities Team. I will be more than happy to assist you.
First, can you please share the .txt file that the Intel® Processor Diagnostic Tool generates? Furthermore, have you tried restoring the BIOS settings back to default? Additionally, can you try testing your processor into a different motherboard?
Antony S.
RBeck2
Hello Antony,
here is the txt file.
at the moment the bios runs with default settings. Sorry but there is no possibility to testing another mainboard.
Many thanks in advance.
Hello, RaBe83. Thank you for your response.
For me to continue investigating into this, please share with us the following:
Antony S.
RBeck2
Hello Antony,
should I turn off the cores in Windows or in Bios?
Ok I turned off the cores in Bios, here the results. One question are five minutes stress test enough?
One Core
Two cores
Three cores
Four cores
RBeck2
and the rest
additional one test with 4 cores for one hour
Thank you very much for the information provided, RaBe83.
Allow me to double check the reports. I will be back to you soon.
Antony S.
Hello, RaBe83. Thank you for your patience.
By checking the results of the reports provided; I am afraid that your processor is defective. I have sent you a private message in order to discuss warranty information. Please check you inbox.
Antony S.
