Processors
14913 Discussions
I7 6700k not working at it's potential.
SRedm1
Ok I just bought this processor and it is not benching at the correct speeds. I've messed around with the simple BIOS options. I have selected the Sync all cores option and it make a very slight difference in my score for the CPUZ bench. I have done minor over clocks because someone recommended it might be a lazy CPU. I was also told it was being thermally throttled. I have had the freaking heat sink off and on so many times messing with thermal paste. I will post all the results of my tests below.
CPUZ, Hyper Pi and Prime 95 was used for these tests. I used the blend test for around 1:20 seconds for Prime 95. I am not a very technical guy, I would like to see if my processor is faulty.
Tests
http://imgur.com/a/dzof7 CPU Tests 09Nov2015 - Album on Imgur
Specs
CPU: I7 6700k
GPU: Sapphire Radeon 280 3gb
Ram: 8gb
PSU: Thermal Lake TR2 600 watt.
Mobo ASUS Z170-Plus
CPU fan http://www.amazon.ca/gp/product/B0077POH8M?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00 http://www.amazon.ca/gp/product/B0077POH8M?psc=1&redirect=true&ref_=oh_aui_detailpage_o00_s00
Cesar_B_Intel
Hello Redmond91,
We do not validate Benchmarks, and do not recommend overclocking your processor. However, if you want to test your CPU, please try Intel® XTU which is a simple Windows*-based performance tuning software for novice and experienced enthusiasts to overclock, monitor, and stress a system. The software interface exposes a set of robust capabilities common in most enthusiast platforms along with special new features available on new Intel® Processors and Intel® Motherboards. You may download it from https://downloadcenter.intel.com/downloads/eula/24075/Intel-Extreme-Tuning-Utility-Intel-XTU-?httpDown=https://downloadmirror.intel.com/24075/eng/XTU-Setup-exe.exe Intel® Extreme Tuning Utility (Intel® XTU)
Additionally, please run the https://downloadcenter.intel.com/download/19792/Intel-Processor-Diagnostic-Tool-64-bit- Download Intel® Processor Diagnostic Tool (64-bit) and post here the results.
Please make sure you are running defaults at the BIOS on your motherboard.
Caesar B.
*Other names and brands may be claimed as the property of others.
