The processor package can rise sharply to 60 -70 degrees, which is necessary to do in the BIOS for the minimum temperature of the motherboard MSI Z270 Gaming Pro Carbon / BIOS update does not help! When you run the program, the temperature of the processor rises to 60-70 degrees! What voltage is required for the processor? What you need to configure on the motherboard? I do not overclock, all components are new! How to fix temperature fluctuations? and is it critical? Stress test AIDA64, 1 hour = 86-88 degrees! OCCT 1 hour = 90 -92 degrees! Games = 72 ~ 76 degrees! Is it dangerous for the system and processor? Here is my video: https://www.youtube.com/watch?v=DK4iyw7lZCA
Your temperatures are fine.
Doc
Yea, 60c to 70c is not hot at all. The processor is completely happy at these temperatures. Come back if your temperatures spend any considerable amount of time at levels above 95c. Then you need to be concerned.
