Processors
14866 Discussions
Intel® Core™2 Duo CPU E4400 @ 2.00GHz é meu processador não aceita virtualização, qual modelo de rocessador que aceite virtualização minha placa mãe é GIGABYTE GA 945 GCM-52-C, preciso do modelo de processador que possa substituir grato
vmaia
Amy_C_Intel1
Hello vmaia, Thank you for posting on the Intel® Communities. Intel no longer provides support for this product. Since you are looking for compatibility options you need to check with you computer manufacturer. Amy C Intel Customer Support Technician Under Contract to Intel Corporation
n_scott_pearson
According to its datasheet, your Gigabyte GA-945GCM-S2C motherboard supports Intel Core 2 Duo, Intel Core 2 Quad and Intel Core 2 Extreme Desktop processors.
The following Intel Core 2 Duo processors both support virtualization and are in the CPU Support list for your motherboard:
E6300, E6320, E6400, E6420, E6540, E6550, E6600, E6700, E6750, E6850, E7600, E8200, E8300, E8400, E8500 and E8600.
The following Intel Core 2 Quad processors both support virtualization and are in the CPU Support list for your motherboard:
Q6600, Q6700, Q9300, Q9400, Q9450, Q9505, Q9505S, Q9550 and Q9650.
The following Intel Core 2 Extreme processors both support virtualization and are in the CPU Support list for your motherboard:
X6800, QX6700, QX6800, QX6850, QX9650 and QX9770.
Note: Before installing any of these processors -- that is, while still using your old processor -- you must upgrade your board's BIOS to version F6d.
My recommendation? Get a Intel Core 2 Extreme QX9770 if you can find one.
