ich habe eine Intel Core i5 3350P in dem Rechner von meinem Sohn vor 4 Monaten eingebaut, aber leider letzte Woche hatte sich bei normaler Benützung nicht mehr reagiert und der Rechner hat seitdem sich nicht mehr startenlassen und Motherboard habe ich auch ausgetauscht. Hat Jemand ein Tip?
Viele Grüsse
Hello farwardin,
For processor troubleshooting you may want to test this unit into a different board. Have you tried using a different power supply?
Hallo,
the power supply working by contacting green to black at it's big connector to motherboard. I have changed to a new board.
Hallo,
I have checked my processor and it seems to work. I installed again in the new motherboard, but I hear starting the boot sequence and stopping all activities with motherboard-start and restarting with continues beeps (over 30 beeps) and black monitor. I don't know why? The processor fan working good.
Hello Farwardin,
Please test the system out of the chassis with minimum configuration such as motherboard, power supply, processor and one memory stick.
This procedure is in order to discard any grounding coming from the chassis.
regards,
![](/skins/images/7FC17B7B85029576C25F1E43CE255B51/responsive_peak/images/icon_anonymous_message.png)
