So a little quick background. I order all these parts earlier this year and put them together. The computer worked fine. When I brought it home from college and it started up then shut off and there was no response.
Since then I have warranty replaced everything besides the ram in the past month. I am now getting a weird boot issue.
Here is what I have for specs:
PSU- Rosewill LIGHTNING-800 800W Continuous @ 50°C, Intel Haswell Ready
CPU- Intel Core i7-4770 Haswell Quad-Core 3.4GHz LGA 1150
MOBO- GIGABYTE GA-Z87X-OC LGA 1150 Intel Z87
RAM- G.SKILL Ares Series 16GB (4 by 4GB)- Only using one stick
I am trying to get the board to post. I have minimal plugged in.
When I try to turn it on it boots up for about a second CPU fan spins then shuts off. There is no error number on the LED of the MOBO but it does flash and it looks like a 0 but it all happens so quickly. I have tried all sticks of RAM, checked the CPU and all that.
Any advice would be amazing
Thank you,
Matt
- Tags:
- Haswell
Hello Matt, thanks for joining the Intel communities.
These are some troubleshooting steps you can follow for this kind of behavior:
- Test the system using minimum configuration (motherboard, processor, power supply and one memory stick) out of the chassis.
- Remove the CMOS battery for about an hour. This link shows the process on Intel Motherboards, but you can check it. http://www.intel.com/support/motherboards/desktop/sb/CS-002839.htm Desktop Boards — CMOS Battery
If you have access to another system, please check the following link. It also provides troubleshooting steps on Intel motherboards, but it is also very complete http://www.intel.com/support/motherboards/desktop/sb/CS-029511.htm Desktop Boards — No Boot Troubleshooting Wizard
![](/skins/images/54BF544B471F3F61DFD338F1D58F9426/responsive_peak/images/icon_anonymous_message.png)
