We are using Window 10 IOT 2021 Enterprise OS and trying to install the below updates using the DISM command but getting error:
DISM /Online /Add-package /PackagePath:G:\7ca48837-d0fb-4b41-b1b0-039016f9e4ec_f965ff0f3654bd6b63115af309370e1aa88d22b0.cab
Intel System: https://www.catalog.update.microsoft.com/Search.aspx?q=Intel+-+System+-+2131.1.4.0
Intel Ports: https://www.catalog.update.microsoft.com/Search.aspx?q=Intel+-+Ports+-+2131.1.73.0
Basically i m trying to find out the driver and fix the 'Yellow question marks in Device Manager' for below drivers:
Network Controller
PCI Serial Port
PCI Simple Communication Controller
Attached the file for more info.
One post is enough. Double posting is not allowed. Stay with your original post.
Hi All,
Any inputs on above query?
Hello Xing_Mike1,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your computer.
I have noticed that you opened a second thread for this issue. Please refer to that thread since the support will continue there.
Thread: https://community.intel.com/t5/forums/forumtopicpage/board-id/processors/message-id/64068#M64068
I will proceed to close this thread.
Deivid A.
