17336 Diskussionen
Intel Dynamic Tuning Technology Driver device constantly reading and writing to disk. WUDFHost.exe
TimNielsen
Einsteiger
41.835Aufrufe
The process WUDFHost.exe is writing to C:\Windows\ServiceProfiles\LocalService\AppData\Local\Intel\ipfsrv
This is on a Windows 11 x64 LEnovo X1 Carbon Gen 10 device.  This does not seem to be a problem on Windows 10.
I believe the issue is related to Intel's DTPF driver but I haven't confirmed.  Does anyone at Intel know what is going on here?
This problem is noticeably slowing down the systems it affects.  I will be posting same thing on Lenovo forums.  Seems like a driver issue with power management/throttling etc.  I did go into the BIOS and disable Intel Speedstep and all other power management options.  The problem SEEMS to have improved after doing that BUT it did not go away by any means.  Screenshot above was taken after disabling all those power management options in the BIOS.
Intel® Platform Innovation Framework for UEFI Specification
Seems to be the service doing it but I believe there is a driver problem here on Windows 11.  I'm not sure.
17 Antworten
TimNielsen
Einsteiger
41.808Aufrufe
I figured out this is all related to the Intel Dynamic Tuning Technology device drivers.  Upon disabling those devices, the problem ceased.  Stopping the Intel services had no effect.  Had to disable the device driver.  It's running through WUDFHost.exe and it's still writing to that location I listed above but it's doing at a less alarming rate.
I ended up updating 3x firmware on the system.
Since installing these firmware updates, the system is running a lot better.  However, I still think there's something wrong with that Intel Dynamic Tuning Technology driver.
Not closing the book on this yet.
TimNielsen
Einsteiger
41.807Aufrufe
Well, that didn't fix it.  Issue returned.
Over a 2.5 minute period, the WUDFHost.exe process (that is handling the Dynamic Tuning Technology User Mode Driver), read and wrote to 12,500 times per file in the folder.  There are 8 files that it's constantly creating and reading.  So that's 12,500 * 8 = 100,000 operations in a 2.5 minute period of disk access.
That's not even counting the registry reads and writes this is doing.  I did some more investigating and it appears that this is also used by the Intel Innovation platform Framework.  So more than just the Dynamic Tuning is responsible.  HOWEVER, if you disable only the dynamic Tuning software device in device manager.  The numbers drop substantially.
I except a software device like this to access the disk and registry occasionally, but there is absolutely something wrong with the Intel Dynamic Tuning Technology software device driver.
Screenshot for details on the files it's reading and writing multiple times a second.  This is not the data that I referenced above, I cleared that procmon.
TimNielsen
Einsteiger
41.722Aufrufe
AlHill
Superuser
41.720Aufrufe
It is the weekend, so be patient.  "Community support is provided during standard business hours (Monday to Friday 7AM - 5PM PST)."
TimNielsen
Einsteiger
41.665Aufrufe
Confirmed that the previous version of the driver also has this issue.  I would assume this driver is the same for all ADL platform.  Anyone out there with ADL willing to do a procmon for me?
Setup your procmon with the following filters to easily see the issue.
Operation contains File
Path contains C:\Windows\ServiceProfiles\LocalService\AppData\Local\Intel\ipfsrv\
I just tried downgrading the driver to a version from march but no change.  Also confirmed this is happening on all Windows 11 ADL machines in my company.
Jocelyn_Intel
Mitarbeiter
41.656Aufrufe
Hello, @TimNielsen
Thank you for posting on the Intel® communities.
Please be aware that we can help you with testing your processor's health, processor issues, and graphics/wireless problems (Graphics Forum, Wireless Forum).
However, since the Intel Dynamic Platform and Thermal Framework (DPTF) Driver is provided by the Original Equipment Manufacturers (OEM), we recommend you contact your System Manufacturer for further assistance with this issue.
Jocelyn M.
TimNielsen
Einsteiger
41.592Aufrufe
Sigh, ok.  I've already done that but I am looking for more support on the issue.  This is not just a "me" problem.
Jocelyn_Intel
Mitarbeiter
41.580Aufrufe
Hello, @TimNielsen
Thank you for your reply.
I understand your discomfort about your issue, however, Computer manufacturers can customize how Intel® DTT works in their driver software. If you are experiencing issues with Intel® DTT, we recommend that you first check with your computer manufacturer and use the driver software provided by them.
This is specified in the public article about Intel® DTT, at the end: Intel® Dynamic Tuning Technology (Intel® DTT) User Guide
Jocelyn M.
RobertoM
Einsteiger
28.718Aufrufe
Dear Customer Support,
I am experiencing the same issue with an ASUS Vivobook. The WUDFHost.exe process goes to 25% CPU (half if in low power mode) for long periods of time without any other process using CPU.
Given that the driver seems to be Intel ... and that it affects multiple manufacturers it should be Intel looking at it. The driver should not consume such amount of CPU, no matter how bad manufacturers configure it.
I tried suspending the process with Process Explorer, which brought CPU consumption of that process to zero. Is this safe? What is the impact?
Roberto.
Jocelyn_Intel
Mitarbeiter
41.463Aufrufe
Hello, @TimNielsen
I hope you are doing great.
As we have not heard back from you, we will proceed to close this thread now.
If you need assistance with other matters, please feel free to contact us and submit a new question as this thread will no longer be monitored.
Jocelyn M.
sebastienbo
Einsteiger
39.386Aufrufe
He is not replyijg because you are not helping with all your questions.
You are not investigating yourself, you are making him do all the work...
Is certainly is not pltaform dependand, because I have the same problem on a dell sff computer and a ASUS rog gaming laptop.
This problem seems to exist only on windows 11 machines and in combination with the latest Intel CPU's
I suspect it might have to do something with the  Efficiency cores (re-priotizing all the time)
likbez
Einsteiger
18.996Aufrufe
Not really only on Windows 11 and new CPU; in my case it is Windows 10 Pro 22H2 with all applicable updates -- on old CPU i5-1235u inside of Vivobook X1704ZA. This process not only wastes over 25%% of my CPU, but it also damages files on my external media - M.2 NVME SSD inside of USB-3.2 case; after writing to this media and further successull disconnection - I'm loosing many folders and files when I connect the media to another PC or another laptop and it even shows 'unreadable disk structure' with further impossibility to recover the valuable files and folders. It is surprising that none can suggest any solution for this big and continuous problem.
sebastienbo
Einsteiger
39.387Aufrufe
There is deffinitly a problem.
I noticed the same problem. The writes are so intensive that they slow down any pc.
Especially when comming out of sleep mode, then this process acts like a resource hungry process attacking the SSD like a mad man
I hope they will find a fix.
Maybe the developers have some verbose logging on, and forgot to disable it?
Clayzor
Einsteiger
36.446Aufrufe
This silly component and I have had some good times. So far... around 50 hours on the phone with Dell L3 support, and about 100 hours on the chat. I told the last person I was going to send a bill for my services. This has been an ONGOING PROBLEM for a while now. Intel still chooses to blame Dell, Dell blames Intel. And those poor CSM's are stuck in the middle.
x1c
Einsteiger
32.965Aufrufe
I can confirm having the same issue on a Thinkpad Carbon X1 Gen 12 device.  Windows Driver Foundation CPU usage averages 1-2% and is being triggered by ipfsrv.
x1c
Einsteiger
32.870Aufrufe
The Intel Innovation Platform Framework drivers on my Lenovo X1 were dated 2023 with no updates available from Lenovo or Intel that I could find.  I located a newer driver via Dell and gave it a shot - it seems to have worked and fixed the issue for me.
https://www.dell.com/support/home/en-us/drivers/driversdetails?driverid=30cpf
likbez
Einsteiger
18.995Aufrufe
Your links is showing `Driver unavailableWe're sorry, the driver you are looking for is no longer available.` In my case the date of WUDFHost.exe is 21.07.2025 and the problem still brings a lot of inconveniences despite any further updates of the system.
Antworten
