Processors
14784 Discussions
Intel Processor Diagnostic Tool: Temperature test fails
TWolf1
perhaps someone can tell me why the temperature test fails with an old Pentium D 915 2,80 GHz.
Thank you in advance.
Protocol:
--- Temperature Test ---
Version 1.0.12.32b.W
Digital sensor is not supported.
..not inside 0xBB --
Temperature not supported.
Test Result - FAIL
Expected Greater than 1 degrees below max
Received 0 degrees below max
Entering run forever
Hello, Me2016 :
  • What is the Intel® Processor Diagnostic Tool version you have installed?
  • Could please attach the full report?
  • Let me know your motherboard model.
Amy.
TWolf1
thank you for your reply.
Intel® Processor Diagnostic Tool Version:
IPDT x86 - Revision: 3.0.0.25.W
Motherboard model:
ASRock, G41M-VGS3 / G41M-VS3
Full report:
--- IPDT x86 - Revision: 3.0.0.25.W
--- IPDT x86 - Start Time: 17.05.2016 16:52:47
Intel(R) spbc Module Test
Module Version: 1.0.7.32b.W
Start Time: Tue May 17 16:52:47 2016
Test Result - PASS
..!!..Processor under test is verified as 'PRODUCTION'..!!..
Processor Manufacturer: GenuineIntel
Processor Brand String: Intel(R) Pentium(R) D CPU 2.80GHz
End Time: Tue May 17 16:52:48 2016
Total Time: seconds: 1
Genuine Intel CPU Test
Module Version: 1.0.12.32b.W
Start Time: Tue May 17 16:52:49 2016
Test Result - PASS
Expected: GenuineIntel
Detected: GenuineIntel
End Time: Tue May 17 16:52:49 2016
Total Time: seconds: 0
Temperature Test
Test Result - FAIL
Expected: Greater than 1 degrees below max
Received: 0 degrees below max
CPU Brand String Test
Start Time: Tue May 17 16:52:50 2016
Test Result - FAIL
Expected String Parts: As Defined in BrandString_LocalConfig.xml
Detected: Intel(R) Pentium(R) D CPU 2.80GHz
Brand String Test Failed!!!
End Time: Tue May 17 16:52:50 2016
CPU Frequency Test
Module Version: 1.0.14.32b.W
Test Result - PASS
Processor Name: Intel(R) Pentium(R) D CPU 2.80GHz
Expected CPU Frequency: 2.80
Detected CPU Frequency: 2.78888
Expected Base Clock: 100
Detected Base Clock: 103.292
QPI link rate Test - Not supported.
Skipping QPI link rate Test.
End Time: Tue May 17 16:53:00 2016
Total Time: seconds: 10
Floating Point Test
Module Version: 1.0.10.32b.W
Start Time: Tue May 17 16:53:00 2016
Test Result - PASS
Million Floating Points per Second, MFLOPS: 187.2
Error: 0
--- Floating Point Test Passed!!!---
End Time: Tue May 17 16:53:02 2016
Total Time: seconds: 2
Prime Number Generation Test
Start Time: Tue May 17 16:53:02 2016
Test Result - PASS
Operation Per Second: 1.32916e+006
Error: 0
--- Prime Number Generation Test Passed!!!---
End Time: Tue May 17 16:53:04 2016
Cache Test
Start Time: Tue May 17 16:53:04 2016
Test Result - PASS
--- Reading Cache Size ---
- Detected L1 Data Cache Size --> 16
- Detected L1 Inst Cache Size --> 0
- Detected L2 Cache Size --> 2048
- Detected L3 Cache Size --> Not Detected.
Cache Size Test Passed!!!
MMXSSE Test
Start Time: Tue May 17 16:53:05 2016
Test Result - PASS
--- Determining MMX - SSE capabilities ---
--- CPU FEATURES DETECTION FOR ---
--- MMX SSE ---
MMX - MMX Supported --> Yes
SSE - SSE Supported --> Yes
SSE2 - SSE2 Supported --> Yes
SSE3 - SSE3 Supported --> Yes
SSSE3 - SSSE3 Supported --> No
SSE4.1 - SSE4.1 Supported --> No
SSE4.2 - SSE4.2 Supported --> No
--- MMX SSE - capabilities check complete ---
MMX Test Result --- PASS
SSE Test Result --- PASS
SSE2 Test Result --- PASS
SSE3 Test Result --- PASS
SSSE3 Test Result --- Not Tested
SSE4.1 Test Result --- Not Tested
SSE4.2 Test Result --- Not Tested
End Time: Tue May 17 16:53:05 2016
AVX Test
Module Version: 1.0.11.32b.W
Test Result - PASS
--- Determining AVX AES PCLMULQDQ capabilities ---
--- AVX/AES/PCLMULQDQ ---
AVX - Advanced Vector Extensions Supported --> No
AVX OS Support - AVX Operating System Supported --> No ---> No Test Required
AES - Advanced Encryption Standard Supported --> No ---> No Test Required
PCLMULQDQ - Polys Carry-Less Multiply Supported --> No ---> No Test Required
--- AVX AES PCLMULQDQ capabilities check complete ---
AVX Compare Test Result --- Not Tested
AES Test Result --- Not Tested
PCLMULQDQ Test Result --- Not Tested
No AVX AES PCLMULQDQ Tests required
End ...
I just want to know, is your system working fine? Is there any issue with it?
Is there any chance you can try with a different version? Also, try setting the default values in your BIOS configuration.
See here for an older version, http://intel-processor-diagnostic-tool.en.lo4d.com/download Download Intel Processor Diagnostic Tool - LO4D.com **
**The content on the above site is not controlled by Intel. This information is offered for your convenience and should not be viewed as an endorsement by Intel for the merchants or services offered there.
Amy.
Hello, Me2016 :
Did you follow my suggestion? Were you able to track this down?
Amy.
ppara5
Valued Contributor I
Someone gave me two well-used Pentium D PCs. I played around with them for a while. Both always ran hot, regardless of whether I used the Intel cooler or an aftermarket one, the fans of which ran at maximum speed. I have no idea if the temperature diode had failed or if the Pentium D has limited usage. One of them ran right on the edge of the maximum temperature. I recycled them both.
If I were you, I'd buy a used E8600 or E8500 from an Amazon Marketplace seller. I've seen them for $20. Your board supports them.
http://www.asrock.com/mb/Intel/G41M-VS3/?cat=CPU ASRock > G41M-VS3
paramountain, thank you for your input, this is very helpful.
Amy.
