Hi all, i have a big problem with my computer's stability at the moment due to my processor overclocked!
A while back i downloaded this tool from intel.com to overclock my processor not knowing what i was doing or the damage it could have caused. I have had numerious problems listing from system failure,bootup problems,system auto restart and many other problems ever since overclocking it.
I would like to have my processor back to the factory settings and the correct drivers installed so it will run smooth again if anyone knows the correct tools and drivers tha i need from intel.com with a link that would be very helpful.
Screenshot results Intel Processor Identification Utility
[IMG]http://i48.tinypic.com/4gt65x.png[/IMG]
Also here is the full dxdiag of my computer:
System Information
Time of this report: 1/23/2010, 15:07:23
Machine name: MY-PC
Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7600) (7600.win7_rtm.090713-1255)
Language: English (Regional Setting: English)
System Manufacturer: Gigabyte Technology Co., Ltd.
System Model: EX58-UD3R
BIOS: Award Modular BIOS v6.00PG
Processor: Intel(R) Core(TM) i7 CPU 920 @ 2.67GHz (8 CPUs), ~2.8GHz
Memory: 8192MB RAM
Available OS Memory: 8190MB RAM
Page File: 1550MB used, 14827MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 11
Display Devices
Card name: NVIDIA GeForce 9800 GT
Manufacturer: NVIDIA
Chip type: GeForce 9800 GT
DAC type: Integrated RAMDAC
Device Key: Enum\PCI\VEN_10DE&DEV_0614&SUBSYS_34AF1458&REV_A2
Display Memory: 4077 MB
Dedicated Memory: 1005 MB
Shared Memory: 3071 MB
Current Mode: 1920 x 1080 (32 bit) (60Hz)
Monitor Name: ViewSonic VX2233wm-3
Monitor Model: VX2233wm-3
The simplest thing would be to enter the BIOS, press Del as it's booting up.
Choose Optimal Defaults, then save and Exit the BIOS.
This should reset the PC to non-overclocked settings
First, load your BIOS setup and restore it's default settings, then if you used a program to OC it, restore it's default settings as well. or manually roll the clockspeed on the CPU back to normal. that should fix the problem.
![](/skins/images/EA93FC3209B97CF1A77FC045C5DDA88A/responsive_peak/images/icon_anonymous_message.png)
