Procesor is Intel(R) Xeon(R) CPU E5620 @ 2.40GHz, 2395 Mhz, 4 Core(s), 8 Logical Processor(s)
BIOS Version/Date Intel Corp. S5500.86B.01.00.0059.082320111421, 2011.08.23
OS Name Microsoft Windows Server 2008 R2 Standard
System Model S5520HC
SMBIOS Version 2.5
Installed Physical Memory (RAM) 24,0 GB
What can cause to spin cooler 7000 rpm ?
1) SDR not flashed on system after integration
2) any fan failure in the system will cause all fans to run fast to compensate.
3) fan connected to the wrong fan header (which makes the systme think you have a failed fan.
Run the SELVIEW tool and check your SEL log for fan or other errors,
Fans are connected to correct fan headers, we checked that. Once the server was shutted down unexpectedly, maybe this caused this problem ?
Here's some system events:
A corrected hardware error has occurred.
Reported by component: Processor Core
Error Source: Corrected Machine Check
Error Type: Cache Hierarchy Error
Processor ID: 52
The details view of this entry contains further information.
I get allways some of them just with different IDs
Use selview (either the In- OS version or the EFI version) and look for critical errors in the log.
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18317&lang=eng&OSVersion=&DownloadType=Utilities%2C%20Tools%20and%20Examples http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18317&lang=eng&OSVersion=&DownloadType=Utilities%2C%20Tools%20and%20Examples
