Processors
14765 Discussions
Intel driver and support assistant setup fail
Lyu5555
I can't setup ıntel driver and support assistant. I upload the imagine and intel ssu detailed information about fail.
Jean_Intel
Hello @Lyu5555
Thanks for your message, I am sorry to hear that you are still experiencing your issue.
Regarding the installation issue that is present on your system, please follow the steps to repair the corrupt registries:
  • Run the Microsoft Program Install and Uninstall troubleshooter:
  • Double click the downloaded file to open the tool
  • Click on Advanced and make sure that the box associated with Apply repairs automatically is checked
  • On the next screen click on Installing
  • Wait until the inspection phase is complete and choose one of the Microsoft Visual C++ Redistributable programs
  • On the next screen click on No, try other fixes, and let the program run its course
  • Repeat the above steps for all Microsoft Visual C++ Redistributable programs installed and restart your computer
I hope you find this information useful.
Jean O.
Jean_Intel
Hello @Lyu5555
Thanks for posting on the Intel communities.
Keep in mind that we may not be able to translate screenshots attached to the thread.
Regarding your issue, since you mentioned that you have issues setting up the program, please try the following steps:
  • Download IDSA, and run the installer as administrator (right-click on the icon and choose Run as Administrator)
  • Add IDSA as an exception to your Antivirus or Firewall or disable these until the installation is completed.
Looking forward to hearing from you.
Jean O.
Lyu5555
Sorry but I tried turning off the antivirus but it didn't work, same issue.
Jean_Intel
Hello @Lyu5555
Jean O.
Jean_Intel
Hello @Lyu5555.
I hope you are doing fine.
Jean O.
Lyu5555
It fixed itself, thanks for help
Jean_Intel
Hello @Lyu5555.
I am glad to hear that the issue is now solved and everything is working fine.
Jean O.
Kelliyoung
I have a friend who has an Alienware and has installed the Intel drivers that are spoken of here and still his laptop isn't being updated with your driver's. Please advise .
AlHill
Do not use IDSA.  Use the Dell support tool.
Also, this thread is a year old.  You should have started a new thread.
Kelliyoung
Tried Dell support tool, didn't work with that either. .. NEXT.
AlHill
Then, talk to dell about their support tool.
