16791 Diskussionen
Intel i3 4160 3.60Hz
Thiago1
Einsteiger
1.164Aufrufe
My processor has integrated video but it does not use dedicated GPU memory Intel HD Grapichs 4400Capturar.PNG
5 Antworten
n_scott_pearson
Superuser
1.133Aufrufe
Not sure what you think your issue is. This is normal.
In 4th gen processor configurations, you can increase the dedicated graphics memory in the BIOS and it will be passed through to the GFX driver.
Thiago1
Einsteiger
1.123Aufrufe
This doesn't work, I've already tried the BIOS, is there any other option?
n_scott_pearson
Superuser
1.118Aufrufe
What exactly is your problem? Your processor and drivers are working as they should. Up to 50% of the available RAM can be allocated for GFX usage as needs dictate.
If you have a game that is complaining about the dedicated memory being too small, this is a bug in the game! You need to talk to the game developers about a fix.
Thiago1
Einsteiger
1.110Aufrufe
100% of the dedicated GPU memory is not being used and any game has low performance
n_scott_pearson
Superuser
1.040Aufrufe
Regarding the first complaint: specious drivel. Regarding the second: you have an ancient processor and it's performance is always going to be low. There's nothing that you can do about it other than upgrade to a lot newer system.
Sorry, gotta be brutally frank,
Antworten
