Processors
13854 Discussions
Intel i7 4702MQ - CAN IT BE BOOST UP IN WINDOW 10 FROM 2.2GHz to 3.2GHz?
AndyCheung1959
Dear Sirs,
I have a Acer Aspire V3-772G with Intel Core i7-4702MQ with 2.2GHz, upgrade to
Window 10, can I turbo boost up to 3.2GHz? Please help, thanks.
Andy Cheung1959
DeividA_Intel
Hello AndyCheung1959,
Due to this product being discontinued (Intel® Core™ i7-4702MQ Processor ), Intel Customer Service no longer supports inquiries for it, but perhaps fellow community members have the knowledge to jump in and help. You may also find the Discontinued Products website helpful to address your request. Thank you for understanding.
Discontinued Products:
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
n_scott_pearson
Super User Retired Employee
In the right situations, the processor should automatically boost up to 3.2GHz. This would be when a single Core is active and the processor is relatively cool. There are other factors that could affect this, however; I've only talked about two. For example, the laptop manufacturer may have provided a crappy cooling solution and locked the processor to lower boost limits. As well, some laptop manufacturers will also lock to lower boost limits to make up for a crappy battery subsystem.
Hope this helps,
....S
