16958 Discussions
Intel's recommended BIOS values for i7-12700K
EmDzei
Hi!
I have ASUS Prime Z690-A motherboard and it's newest BIOS version 3501. Intel have forced motherboard makers to add "Intel's Default Settings", but after shoosing that, they are not.
I cannot find on Intel's webpage values for:
ICCMAX
PL1
PL2
Yes, and after shoosing "Intel's Default" the value CEP is disabled; it should be enabled by Intel.
ICCMAX is amperes, both PL1 and PL2 are wats. Can someone who found Intel's specs link the webpage or just tell those right values. Better than 'unlimited' like 4096W..
pressed_for_time
Valued Contributor II
The values of PL 1 and PL 2 appear on the Intel CPU Specifications as Processor Base Power and Maximum Turbo Power. See the graphic below which is an extract from the specs for the Core i7 12700K
These values should appear in the ASUS BIOS under Advanced->Ai Tweaker->Internal CPU Power Management. The Long Duration Package Power Limit is PL 1, the Short Duration Package Power Limit is PL 2. There should also be a number displayed in this section of the BIOS showing the maximum current, this should be less than 511.75 A.
EmDzei
Thank you for your quick reply.
Checked by HWiNFO and it shows ICCMax 240 A and both PL1 and PL2 was 190 W.
I will set PL1 to 125 W, but the 'less than 511.75 A' for ICCMax sounds too much, if Intel's recommended value for i9-14900K(S) is 400 A. I think I keep it what ASUS have planned: 240 A.
But I was very interesting what is the value what Intel itself have planned to i7-12700K CPU. That information is VERY hard to find on their webpage or Internet or by AI like Copilot (Edge AI). 'It depends what CPU you have' starts many answers. I think Intel knows exactly what this ICCMax value should be - regardless of motherboard manufacturers.
Marcel-Dupont
You can actually find it in the "12th Generation Intel® Core™ Processors Datasheet, Volume 1 of 2" (655258).
It can be found here: https://edc.intel.com/content/www/us/en/design/ipla/software-development-platforms/client/platforms/alder-lake-desktop/682436/
Table 1. Core i7 12700K => S-Processor Line LGA1700, TDP 125W, 8P+4E Cores
Table 19. S-Processor Line LGA / 8+4 Core 125W => PL1 125W, PL2 190W
Table 76. S-Processor (125W) 8+4 Core => ICCMAX 240A
EmDzei
