Hello guys im in a bit of dilema here and i think my CPU is dead. Installed on a new motherboard and the PC will power on for a second and the off. AT fisrt i though "wao dead mobo" but then after much tested i think i may have a dead CPU. What i did...
I had another motherboard with another same CPU working perfect so what better example than to connect the presumed dead CPU into a working system and there it was, same issue powers on 1 sec then off. Just to rule out the mobo i used the know working one into the new mobo and posts.
DO you think that is totall prove the CPU may be dead or im missing something?
Thanks in advance
Topic Options
