I wish to perform a microcode/firmware update for the Celeron N2930 and the Atom E3815 under Linux.
I've downloaded the archive microcode-20180703.tgz, because both processors are listed as supported on this page:
https://downloadcenter.intel.com/download/27945/Linux-Processor-Microcode-Data-File https://downloadcenter.intel.com/download/27945/Linux-Processor-Microcode-Data-File
Unfortunately the necessary microcode files (06-37-08 and 06-37-09) seem to be missing.
Are Bay Trail platforms not supported (yet)?
If that is the case, will they be supported in the future and when?
Thanks in advance!
Hello M.I.K.e,
Thank you for contacting our support; it will be more than a pleasure to assist you.
In order for me to assist you better, please provide us with the system model and brand of your two machines (where Intel Atom® E3815 and Intel® Celeron® N2930 are installed).
As well, can you tell us the specific reason why you need the microcodes?
Can you provide us with a longer description of the issue that you are experiencing?
I hope to hear from you soon.
Diego S.
Thanks for your answer, Diego.
The processors come on these two boards:
Jetway NF9N-2930
Axiomtec ICO300
We sell these as part of a solution, and some customers are very security-aware. We are basically just waiting for them to ask us about fixes regarding Meltdown and Spectre.
While the systems are mostly a black-box to our customers and we almost exclusively run our own software, I guess news about "NetSpectre" (however unlikely such an attack might be) won't improve matters:
https://arstechnica.com/gadgets/2018/07/new-spectre-attack-enables-secrets-to-be-leaked-over-a-netwo... New Spectre attack enables secrets to be leaked over a network | Ars Technica
The systems mainly run headless and a lot of our customers aren't that computer-savvy, so we'd prefer to issue microcode updates with an upcoming Linux update instead of a more complicated BIOS update.
Thanks in advance.
Take care,
Mike
Faster solution would be to download necessary microcode from Microcode Extractor https://github.com/platomav/MCExtractor site.
For Atom E3815 it should be: https://github.com/platomav/CPUMicrocodes/blob/master/Intel/cpu30679_plat0F_ver0000090A_2018-01-10_P... CPUMicrocodes/cpu30679_plat0F_ver0000090A_2018-01-10_PRD_252563C5.bin at master · platomav/CPUMicrocodes · GitHub
For Mobile Celeron N2830: https://github.com/platomav/CPUMicrocodes/blob/master/Intel/cpu30678_plat0C_ver00000836_2018-01-10_P... CPUMicrocodes/cpu30678_plat0C_ver00000836_2018-01-10_PRD_B221B0E8.bin at master · platomav/CPUMicrocodes · GitHub
Just rename that files to 06-37-09 and 06-37-08 respectively.
Note: platform indicator (plat) is quite important. I've checked Jetway NF9HG old BIOS with MCExtractor and there is microcode for 06-37-08 CPU and platform 0x0C and 0x01.
Thanks for the hint, Gorbush!
I tested the microcode on the E3815 and it seems to work. While variant 3a ("rogue system register read") isn't fixed yet, it adds IBRS and IBPB.
I also found a newer revision of the microcode for one of our i5 processors. While there was a microcode file for it in the Intel archive, the newer revision added a fix for the 3a variant.
Thanks again for pointing me to this useful resource.
