- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Suscribirse a un feed RSS
- Resaltar
- Imprimir
Hi, I am planning to build my next PC using both parts below:
CPU = I7-12700K
MB = Gigabyte Z690 Aorus Pro DDR5
However, when I look at this CPU specs for memory compatibility list, it only says DDR5 max 4800 MT/s where this MB memory compatibility list is in MHz!
All memory lists on the internet are in MHz, not in MT/s.
This CPU MB compatibility list does include this MB.
I know there is no way to translate/convert MT/s into MHZ but could you at least give me the list of compatible DDR5 compatible with this CPU so I can then do a correlation with this MB's own memory compatibility list?
Enlace copiado
- Marcar como nuevo
- Favorito
- Suscribir
- Silenciar
- Resaltar
- Imprimir
Compatibility is determined by the Memory Reference Code provided in the BIOS. You thus need to consult with Gigabyte to determine what memory is supported. Note that they usually have a web page or document that details the compatible memory. Look it up via the support page for your motherboard.
- Marcar tema como nuevo
- Marcar tema como leído
- Favorito
- Suscribir
