I have a i7-860 processor and was currently using Intel dp55w motherboard and now this motherboard is now working.
I need a alternate motherboard which supports i7-860 and has LGA1156 socket.
Any suggestions would be helpful.Thank you
- Tags:
- Intel Sockets- i5i7
You will have to search sites like ASUS, MSI, EVGA, ASROCK, and such to find a compatible board. And, it is not just the socket you need to be sure of. The motherboard bios must also support your processor.
Now, all that being said, you would do much better to dispose of this old processor (in my opinion).
Doc
If you want to replace it with another Intel Desktop Board, here are some that I found on eBay...
https://www.ebay.com/p/Intel-DP55WB-LGA1156-Socket-BLKDP55WB-Motherboard/78145250?iid=142257312246
https://www.ebay.com/p/Intel-DP55WB-LGA1156-Socket-BLKDP55WB-Motherboard/78145250 (New) Intel Desktop Board DP55WB | eBayhttps://www.ebay.com/p/Intel-DP55WB-LGA1156-Socket-BLKDP55WB-Motherboard/78145250?iid=142257312246
https://www.ebay.com/itm/Intel-Desktop-Board-Motherboard-DP55WB-LGA-1156-Socket-w-HEATSINK/232741110998 (Used) Intel Desktop Board DP55WB | eBay
https://www.ebay.com/itm/Intel-Desktop-Board-DH55HC-Mainboard-Motherboard-Socket-1156-No-CPU-No-RAM/173418215336 (Used) Intel Desktop Board DH55HC | eBay
Hope this helps,
Zebronics Intel H55 Chipset Motherboard Socket 1156 Zeb55 https://www.amazon.in/dp/B01M750YR7/ref=cm_sw_r_cp_apa_i_mtHwBbEB7CF34
Can you guys check if this is compatible?
![](/skins/images/B7BA37F9CE4B52FF7CAE1FB0388839C8/responsive_peak/images/icon_anonymous_message.png)
