Processors
14793 Discussions
No update for the graphics driver
Hossein887
I need a version 31.0.101.4952 of the graphics driver to play Modern Warfare 3
but for my processor this update is not supported
My processor: core i3 10100
VonM_Intel
Hi, Hossein887.
Thank you for posting in our Community.
You've encountered an issue where this update is not supported for your processor, which is the Intel Core i3 10100. Your processor comes with Intel UHD Graphics 630. The driver updates for this integrated GPU might not be the same as those for the Arc and Iris Xe GPUs. It’s possible that the specific driver version you mentioned (31.0.101.4952) is not compatible with the UHD Graphics 630 on your i3-10100. It's common for certain graphics driver updates to have compatibility requirements or limitations based on the hardware they're intended to support. In this case, the Intel Graphics Driver version 31.0.101.4952 is indeed optimized for playing “Call of Duty: Modern Warfare III” and other games. However, this driver version appears to be primarily designed for Intel’s Arc and Iris Xe GPUs.
Furthermore, while having knowledge of your processor is beneficial, I would appreciate additional details about your system configuration. Kindly generate and provide the Intel System Support Utility (SSU) report, allowing me to verify essential information such as the operating system build, graphics driver version and model, and any system-level errors logged. This will enable me to assist you more effectively.
Looking forward to your response. Have a nice day!
Von M.
Crusher24
Hi, I am also facing the same problem, is there anyway to update the drivers to 31.0.101.4952 in order to play Modern Warfare 3?
I have a intel uhd graphics 630
My processor: Intel i7-8700
VonM_Intel
Hi, Hossein887.
I trust you're doing well.
I have not heard back from you, we will close this inquiry now. If you need further assistance, please submit a new question as this thread will no longer be monitored.
Von M.
