Hello, I am inquiring about my CPU regarding this boot issue I am having. NZXT z490 motherboard, and when I have 2 RAM slots installed it doesn't display and has a DRAM error on LED troubleshooting lights. So, when I figured out, I can boot with 1 RAM stick I ran the INTEL PDT and the CPU has passed everything. Does the PDT check the memory controller and all the memory channels even with only 1 stick installed? I have also ordered a replacement motherboard as I got this one used and supposedly it was working perfectly before they owner took it out to replace it. They also gave an excuse that they replaced it due to different color, however I am inclined to believe that they had the same issue and are just not telling me. Any help at all would be appreciated.
1. It is not clear from your post if the PC boots with each one from the both RAM sticks or only from one of them?
2. You may download MEMTest86 Free application and prepare bootable USB to test your RAM.
Leon
One more thing. Are you aware that when installing only two DIMMs, their should be installed in slot A2 and B2?
Leon
![](/skins/images/48A1642489FEF8D34D940AC6791CBDC2/responsive_peak/images/icon_anonymous_message.png)
