Tenho um notebook HP Pavilion 14-v065br com o processador Intel Core i7-4510U de 4ª geração e 2,0 GHz, com Turbo Boost para até 3,1 GHz. Meu computador veio com o Windows 8 instalado, e tudo funcionava perfeitamente, porém ao formatar e instalar o Windows 7 64 bits, o processador só ficou com os 2,0 GHz de clock, perdeu o turbo que acelerava para 3.1 GHz. Alguém poderia me informar como devo proceder para voltar a ter o turbo no processador? Desde já agradeço!
Hello HasseArthur
Thank you for posting in the Intel Community.
The Intel® turbo boost technology is a feature that is enable or disable on the system BIOS, in your case in the HP motherboard BIOS or you can also try confirming that the operating system power plan is set to high performance.
By he way I also have found the following HP communities for a similar issue than yours (https://h30434.www3.hp.com/t5/Notebooks-Archive-Read-Only/Enable-Turbo-Boost/td-p/5632277) for reference you can review it.
Please be aware that the content on that site is not controlled by Intel®. This information is offered for your convenience and should not be viewed as an endorsement by Intel® for the merchants or services offered there.
We recommend also contacting HP for bios settings or updates.
https://support.hp.com/us-en
NOTE: We only provide support in English and we use a translation tool for your post.
Hope this helps.
Leonardo C.
Under Contract to Intel Corporation
