Processors
15143 Discussions
Please check your Processor Thermal Solution
My PC was working well but since one week, it regularly shuts down when unexpected.
I tried the Intel Processor Diag tool and I obtain an error on Temp.
the file of test is the folowwing.
I need HELP
Thank you
--- IPDT64 - Revision: 4.0.0.29
--- IPDT64 - Start Time: 30/01/2017 19:03:55
CPU1
Intel(R) spbc Module Test
Module Version: 1.0.8.64b.W
Start Time: Mon Jan 30 19:03:55 2017
Test Result - PASS
..!!..Processor under test is verified as 'PRODUCTION'..!!..
Processor Manufacturer: GenuineIntel
Processor Brand String: Intel(R) Core(TM) i7 CPU 870 @ 2.93GHz
End Time: Mon Jan 30 19:03:58 2017
Total Time: seconds: 3
CPU1
Genuine Intel CPU Test
Module Version: 1.0.12.64b.W
Start Time: Mon Jan 30 19:03:58 2017
Test Result - PASS
Expected: GenuineIntel
Detected: GenuineIntel
Total Time: seconds: 0
CPU1
CPU Brand String Test
Module Version: 1.0.14.64b.W
Test Result - PASS
Expected: Intel(R) Core(TM) CPU @
Detected: Intel(R) Core(TM) i7 CPU 870 @ 2.93GHz
Intel(R) Core(TM) processor detected..!!..
CPU1
Floating Point Test
Module Version: 1.0.11.64b.W
AVX is NOT supported in your OS
FMA3 not supported
Test Result - PASS
Million Floating Points per Second, MFLOPS: 363.09
Error: 0
--- Floating Point Test Passed!!!---
End Time: Mon Jan 30 19:04:00 2017
Total Time: seconds: 2
CPU1
Prime Number Generation Test
Module Version: 1.0.13.64b.W
Start Time: Mon Jan 30 19:04:00 2017
Test Result - PASS
Operation Per Second: 381700
Error: 0
--- Prime Number Generation Test Passed!!!---
End Time: Mon Jan 30 19:04:02 2017
CPU1
Cache Test
Start Time: Mon Jan 30 19:04:02 2017
Test Result - PASS
--- Reading Cache Size ---
- Detected L1 Data Cache Size --> 32
- Detected L1 Inst Cache Size --> 32
- Detected L2 Cache Size --> 256
- Detected L3 Cache Size --> 8192
Cache Size Test Passed!!!
CPU1
MMXSSE Test
Test Result - PASS
--- Determining MMX - SSE capabilities ---
--- CPU FEATURES DETECTION FOR ---
--- MMX SSE ---
MMX - MMX Supported --> Yes
SSE - SSE Supported --> Yes
SSE2 - SSE2 Supported --> Yes
SSE3 - SSE3 Supported --> Yes
SSSE3 - SSSE3 Supported --> Yes
SSE4.1 - SSE4.1 Supported --> Yes
SSE4.2 - SSE4.2 Supported --> Yes
--- MMX SSE - capabilities check complete ---
MMX Test Result --- PASS
SSE Test Result --- PASS
SSE2 Test Result --- PASS
SSE3 Test Result --- PASS
SSSE3 Test Result --- PASS
SSE4.1 Test Result --- PASS
SSE4.2 Test Result --- PASS
CPU1
FMA3 Test
Module Version: 1.0.10.64b.W
Start Time: Mon Jan 30 19:04:03 2017
Test Result - PASS
--- CPU Features Detection ---
FMA3 - Supported --> No
FMA3 support is NOT detected on your Processor
FMA3 Test Result --- Not Tested
End Time: Mon Jan 30 19:04:03 2017
CPU1
AVX Test
Module Version: 2.0.8.64b.W
Test Result - PASS
AVX - Supported --> No
AVX2 - Supported --> No
AVX512 - Supported --> No
AVX OS Support - Supported --> No ---> No Test Required
AES - Supported --> No ---> No Test Required
PCLMULQDQ - Supported --> No ---> No Test Required
Minimum Operating System requirements are
Windows 10,8.1,8,7 SP1, Windows Server 2008 R2 SP1
Linux kernel version 2.6.30
CPU1
IMC Test
Test Result - PASS
--- Reading Memory Size ---
Hello city35:
Thank you very much for providing the results of the Intel® Processor Diagnostics Tool.
Normally, we should be able to verify the clock speed of the processor, the expected and the one detected, for some reason that information is not showing in the report.
Could you please run the tool again in order to verify if we can get that information?
Are you doing overclocking?
How often is the PC going off by itself, after a few hours?
Besides the fan that came with the processor, are you using another cooling solution inside the case?
Do you have the option to use a different processor on your board or to test your processor on a different board?
Any further questions, please let me know.
Alberto
Hello Alberto,
please find bellow the new test.
the CPU is clearly overlocked!!!
Expected CPU Frequency: 2.93
Detected CPU Frequency: 3.56666
But, i didn't made any modification. I don't know how to do that.
Can you explain, how I can recover the normal situation??
thank you
regards
--- IPDT64 - Start Time: 31/01/2017 18:12:53
CPU1
Start Time: Tue Jan 31 18:12:53 2017
Test Result - PASS
End Time: Tue Jan 31 18:12:53 2017
CPU1
Test Result - PASS
End Time: Tue Jan 31 18:12:54 2017
Total Time: seconds: 1
CPU1
Start Time: Tue Jan 31 18:12:54 2017
Test Result - PASS
CPU1
Floating Point Test
FMA3 not supported
Test Result - PASS
Million Floating Points per Second, MFLOPS: 448.695
Error: 0
End Time: Tue Jan 31 18:12:56 2017
CPU1
Start Time: Tue Jan 31 18:12:56 2017
Test Result - PASS
Operation Per Second: 505975
Error: 0
End Time: Tue Jan 31 18:12:58 2017
CPU1
Cache Test
Start Time: Tue Jan 31 18:12:58 2017
Test Result - PASS
CPU1
MMXSSE Test
Test Result - PASS
--- MMX SSE ---
CPU1
FMA3 Test
Start Time: Tue Jan 31 18:12:59 2017
Test Result - PASS
End Time: Tue Jan 31 18:12:59 2017
CPU1
AVX Test
Test Result - PASS
CPU1
IMC Test
Test Result - PASS
Detected Memory Size is --> 8.00GB
--- Subtest - Memory Size Test Passed!!! ---
--- Integrated Memory Controller Stress Test ---
Memory to be allocated = 1048576 byte
Memory Allocated.
Test 1 Ones and Zeros Moving Inversions write operations - Passed
Test 1 Ones and Zeros Moving Inversions verification operations - Passed
Test 2 32Bits Sliding Ones write operations - Passed
Test 2 32Bits Sliding Ones verification operations - Passed
Test 3 32Bits Sliding Zero write operations - Passed
Test 3 32Bits Sliding Zero verification operations - Passed
Memory Deallocated.
--- Subtest - Memory Stress Test Passed!!! ---
Integrated Memory Controller Stress Test Passed!!!
End Time: Tue Jan 31 18:13:00 2017
CPU1
PCH Test
Start Time: Tue Jan 31 18:13:00 2017
Test Result - PASS
LPC deviceID = 0x3b02
Chipset : Intel(R) P55 Chipset
Chipset Stepping : B3
2 device connected to PCI-to-PCI Bridge Controller
1 : Contr�leur IDE standard double canal PCI
2 : Contr�leur d�h�te compatible OH...
Hello city35:
Thank you very much for letting us know that information.
Normally in this case what we recommend to is set the BIOS to defaults, that should be enough to stop the processor for getting overclocked.
There are some scenarios where the board under the default BIOS settings still overclocks the processor, in that case if after trying to restore the BIOS to defaults the problem persists, the best thing to do will be to get in contact with the manufacturer of the board:
Gigabyte's phone number: 1 626-854-9338
Gigabyte's support site: http://www.gigabyte.us/support-downloads/support-downloads.aspx http://www.gigabyte.us/support-downloads/support-downloads.aspx
Alberto
Hello Alberto,
I entered in the bios and it seems that the cpu is in its normal state !!!
Detected CPU Frequency: 2.93107
I did the test again and I have allways an error
do you some other advices?
thank you
regards
Christophe
--- IPDT64 - Start Time: 01/02/2017 20:03:07
CPU1
Start Time: Wed Feb 1 20:03:07 2017
Test Result - PASS
End Time: Wed Feb 1 20:03:07 2017
CPU1
Test Result - PASS
CPU1
Start Time: Wed Feb 1 20:03:08 2017
Test Result - PASS
End Time: Wed Feb 1 20:03:08 2017
CPU1
Floating Point Test
FMA3 not supported
Test Result - PASS
Million Floating Points per Second, MFLOPS: 456.527
Error: 0
End Time: Wed Feb 1 20:03:10 2017
CPU1
Start Time: Wed Feb 1 20:03:10 2017
Test Result - PASS
Operation Per Second: 634591
Error: 0
End Time: Wed Feb 1 20:03:12 2017
CPU1
Cache Test
Start Time: Wed Feb 1 20:03:12 2017
Test Result - PASS
CPU1
MMXSSE Test
Test Result - PASS
--- MMX SSE ---
CPU1
FMA3 Test
Test Result - PASS
CPU1
AVX Test
Start Time: Wed Feb 1 20:03:13 2017
Test Result - PASS
End Time: Wed Feb 1 20:03:13 2017
CPU1
IMC Test
Test Result - PASS
Memory Allocated.
Memory Deallocated.
CPU1
PCH Test
Test Result - PASS
2 : Contr�leur d�h�te compatible OHCI 1394 Texas Instruments
No device connecte...
Hello city35:
Thank you very much once again for letting us know those details.
At this point the next thing to do if you have the option of course will be to swap parts, either to test your board with a different processor or test your processor on a different board, because the problem could be related to either one of those components.
If there is a PC repair store close to you, they might be able to do that for you and swap parts to find out the root of the problem.
In some cases by adding another cooling solution or fan the problem gets fixed, but that will depend on the case you are using and if it has the option to do that.
Could you please provide the part number of the memory RAM you are using?
You can see it on the stick itself, this is in order to make sure the memory is fully compatible with the processor.
If you are using more than one memory stick, please test the PC with one memory stick at the time, this is in order to rule out a possible problem with the stick itself.
Please let me know the results of trying the steps above.
Alberto
Dear Alberto,
I think that the values of the Detected CPU Frequency is the cpu freq when the test is ended. It means, if the test is wrong, the Detected CPU Frequency is the freq at the last test value, and if the test is ok, the Detected CPU Frequency is the expected one, because the cpu has time to come back at its normal value.
I cleaned the heater of the CPU and I replace the thermal grease.
I tried the Intel extrem tuning utility and the cpu stress test. the cpu freq is allways varying (1.2 - 3.0 Ghz) and the cpu temp is allways at the maximum 99°.
do you think that if I change the fan of the CPU, I can obtain a better temp regulation?
thank you
Christophe
Hello city35:
Yes, as a troubleshoot step that is always an option, to test the PC with a different fan could fix the temperature problem, also it will help us to rule out a possible problem with the fan itself. Based on the report from both the diagnostics tool and the XTU it seems to be the processor is in fact getting overheated, and yes you are right about the detected CPU frequency, that is how it works. On the processor diagnostics tool the value for the temperature where it says " Received 1 degrees below max" that value should be higher than 1, to make sure there is no overheating problem.
If you have the option to use another fan please do that, same thing if you can test your processor on a different board or your board with a different processor.
Please let me know the results of using a different fan and if you have the option to swap parts.
Alberto
Hello city35:
I just wanted to check if you were able to try the steps above and if the problem persists or if it was resolved?
Alberto
Hi Alberto
soory for the late answer, but I had no time until now to work on this problem.
I changed the CPU cooler by a new one and now it works well.
thank you for all and this topic can be closed
regards
Christophe
Hello city35:
No problem at all, we understand it takes time to do different tests on the PC.
Thank you very much for letting us know that information, we really appreciate that.
Perfect, excellent, it is great to hear the problem was resolved with the new CPU cooler and now the PC is working fine.
Any other inquiry, do not hesitate in contact us again.
Alberto
