Hi
I made sample board 6ea with designed RPLlake-S.
Processor model: i7-14700T
Motherboard model : RPLlake-S
Bios : Ami bios label 62
The 3ea board is booting well,
but 3 board meet BIOS_RESET_CPL crash when booting up.
But it is booting well as below scenario.
1. The board is booting fail in BIOS_RESET_CPL.
2. The power is off and power on in 5 seond.
3. The box is booting well to shell.
And it is booting fail as below scenario.
1. The box is booting well to shell
2. The power is off and power on after 2 minute.
3. The box is booting fail in BIOS_RESET_CPL.
I don't know which part to debug? (hw issue or bios issue)
Can you give me some info to debug?
Many thanks.
Hello Paul323,
Before we proceed, let me clarify. Are you designing your own motherboard?
Michael L.
HI Michael L.
Before we proceed, let me clarify. Are you designing your own motherboard? YES
We use bios ver. RC code: 0c.00.c6.50
Hello Paul323,
Let me verify first if the components that you are using are known working units.
- The i7-14700T is a known working processor? Did you already tried this on a retails board?
- Have you also tried a different processor on your designed board?
Michael L.
Hi Michael L.
I tried various CPUs, but none of them worked
Hi Michael L.
I tried different motherboards, and they worked fine
But my motherboards is booting fail in BIOS_RESET_CPL.
Hello Paul323,
We will do further research on this matter and post the response on this thread once it is available.
Have a fantastic day, and thank you very much for your patience and understanding!
Michael L.
Hello Paul323,
Thank you for patiently waiting for our update.
Upon checking, we recommend that you should reach out to our Developer Zone Support or get in touch with a Field Application Engineer for specialized assistance. They are the best team who can assist you regarding this inquiry.
Since you will be contacting our Developer Zone, I need to close this inquiry.
Michael L.
![](/skins/images/7FC17B7B85029576C25F1E43CE255B51/responsive_peak/images/icon_anonymous_message.png)
