16771 Discussions
Red light on motherboard! PC won't boot?
L_1
Two weeks ago Two weeks ago now my PC completely switched off and a red light appeared on the motherboard. I've disconnected all other components and have narrowed the problem down to the CPU and the motherboard. The RAM works fine on another PC. I have re-seated the CPU (i7 6800k) along with thermal paste. I have also cleared the CMOS. As soon as I power on the motherboard, there's a click noise and the red light turns on. Any ideas?
AlHill
Motherboard, or the power supply.
Doc
n_scott_pearson
I agree with Al.
First of all, if the issue is occurring at the point where the system is connected to A/C power, this tells us that it is isolated to either the portion of the power supply that provides Standby Power or the portion(s) of the motherboard that consumes this Standby Power. The processor itself is NOT powered in Standby, so it is likely not responsible for the problem in this scenario. If, on the other hand, you have the motherboard configured to automatically power up when power is supplied (restored), the processor could also possibly be involved - but this has rarely been the case in my experience.
When you say that you hear a click when you apply A/C power, is this click coming from the Power Supply or the Motherboard?
Most motherboards utilize a green LED to indicate that Standby Power is being delivered. Is this LED also being lit?
Most LEDs are documented, at least with a label, in the silk screening of the motherboard. What is the label for this red LED?
