Can anyone please provide MSL (Moisture Sensitivity Level) of these parts?
There are some IC, SSD, Transistor, Power supply, PCA Adaptor, Processor, Ethernet controller, Microcircuits and DISK DRIVE on the list and i have also mentioned MPN for each of these parts. Could you please provide the corresponding MSL data for these parts??
Please Provide the Data ASAP,
Thank you!
Manufacturer Part Number | Description |
1 - MA2085 S LN6H | 1 - "MYRIAD X MA2085 |
2 - EN6347QI | 2 - "IC EN6347QI 4A REGULATOR BUCK |
3 - EN5339QI | 3 - "IC EN5339QI 5.5V 3A REG BUCK S |
4 - SSDSC2KG480GZ01 | 4 - "INTEL SSD DC S4600/S4610 SERIE |
5 - E10GSFPSR | 5 - "PURCHASED. ELECTRO-MECH. TRANS |
6 - FXX2130PCRPS | 6 - "POWER SUPPLY. 2130 W AC COMMON |
7 - AXX1100PCRPS | 7 - "POWER SUPPLY. 1100W COMMON RED |
8 - SSDSC2KG480G801 | 8 - "INTEL SSD DC S4600/S4610 SERIE |
9 - SSDSC2KG480G701 | 9 - "INTEL SSD DC S4600/S4610 SERIE |
10 - SSDSC2KB240G801 | 10 - "INTEL SSD DC S4500 OR S4510 SE |
11 - AHWBPBGB | 11 - "OEM. PCA. BRIDGE BOARD FOR G8 |
12 - I350T4V2BLK | 12 - "OEM. PCA. ADAPTER. QUAD PORT G |
13 - X557T2OCPG1P5 | 13 - "OEM. PCA. ADAPTER. OCP X557-T2 |
14 - AXXRMM4LITE2 | 14 - "OEM. PCA. DONGLE. REMOTE MANAG |
15 - X710DA2 | 15 - "OEM. PCA. ADAPTER. DUAL PORT 1 |
16 - I350T2V2BLK | 16 - "OEM. PCA. ADAPTER. DUAL PORT G |
17 - AGFA014R24C2E2V | 17 - "FPGA.AGILEX-F SOC.4X CORTEX- / |
18 - 99AH6A | 18 - "COMMUNICATION PROCESSOR.SNOW / |
19 - 99AH64 | 19 - "COMMUNICATION PROCESSOR.SNOW / |
20 - 99AH7D | 20 - "COMMUNICATION PROCESSOR.SNOW / |
21 - WGI210ATSLJXQ#925131 | 21 - "Ethernet controller I210-AT |
22 - CM8066002061300 | 22 - "Microprocessor Broadwell-EP |
23 - FH8065503553000 | 23 - "MICROPROCESSOR_Microprocessor. |
24 - 99A202 | 24 - "EAGLEOWL / PROD. ADAPT. CIRCUI |
25 - 999NC9 | 25 - "EAGLEOWL / PROD. ADAPT. CIRCUI |
26 - 99AG49 | 26 - "COMMUNICATION PROCESSOR.SNOW / |
27 - 99AFA9 | 27 - "COMMUNICATION PROCESSOR.SNOW / |
28 - 962985 | 28 - "DIG ASIC TRINITY-S |
29 - 99ACTA | 29 - "LYNX 1.1 / PROD. ADAPT. CIRCUI |
30 - 99A99T | 30 - "SAREK MID POWER -40C / MULTI-C |
31 - 99A6AN | 31 - "SAREK MID POWER -40C / MULTI-C |
32 - 99A9ZN | 32 - "SAREK LOW POWER -40C / MULTI-C |
33 - 99A6AR | 33 - "SAREK LOW POWER -40C / MULTI-C |
34 - GGMEADOWWOODB0 SRKTK 99AFHN | 34 - "EAGLEOWL / PROD. ADAPT. CIRCUI |
35 - 5SGSMD5H3F35I3LGAA | 35 - "MICROCIRCUIT/FPGA. STRATIX V. |
36 - 963510 | 36 - "FLASH DISK DRIVE/SSD 240GB Tc= |
37 - 16001 | 37 - "MONGOOSE ASIC / INTEGRATED CIR |
38 - MLAX5608A14B1SE Q07U #99AT5A | 38 - "VERIFICATION COMMUNICATION PRO |
39 - 947361 | 39 - "Ethernet Controller X710-BM2 |
40 - 925133 | 40 - "ETHERNET CONTROLLER.I210-IT. |
41 - 925131 | 41 - "Ethernet controller I210-AT |
41 - 915809 | 41 - "Ethernet Controller i350 PCI |
43 - 934600 | 43 - "MICROCIRCUIT/10GIGABIT ETHERNE |
44 - 976108 | 44 - "COMMUNICATION PROCESSOR AXM56 |
45 - 947636 | 45 - "Microprocessor Broadwell-EP |
46 - 948141 | 46 - "Microprocessor Broadwell-EP |
47 - 976109 | 47 - "COMMUNICATION PROCESSOR AXM56 |
48 - 957488 | 48 - "MICROPROCESSOR_Microprocessor. |
49 - 99A038 | 49 - "COMMUNICATION PROCESSOR.SNOW / |
50 - 99A046 | 50 - "COMMUNICATION PROCESSOR.SNOW / |
51 - HASHADOW WOOD 99ACTA SRKMT | 51 - "LYNX 1.1 / PROD. ADAPT. CIRCUI |
52 - HASHADOW WOOD 99ACT9 QX3D | 52 - "LYNX 1.1 / PROD. ADAPT. CIRCUI |
53 - 99AFHN | 53 - "EAGLEOWL / PROD. ADAPT. CIRCUI |
54 - SRKWG 99AH64 | 54 - "COMMUNICATION PROCESSOR.SNOW / |
55 - SRJF2 99A046 | 55 - "COMMUNICATION PROCESSOR.SNOW / |
56 - SEQUOIA ACRES 99A99T SRKH2 | 56 - "SAREK MID POWER -40C / MULTI-C |
57 - SEQUOIA ACRES 99A6AN SRK6 | 57 - "SAREK MID POWER -40C / MULTI-C |
58 - SEQUOIA ACRES 99A6AK QW01 | 58 - "SAREK MID POWER -40C / MULTI-C |
59 - SEQUOIA ACRES 99A6AR SRK6M | 59 - "SAREK LOW POWER -40C / MULTI-C |
60 - SEQUOIA ACRES 99A9ZN SRKKU | 60 - "SAREK LOW POWER -40C / MULTI-C |
61 - SEQUOIA ACRES 99A6AL QW02 | 61 - "SAREK LOW POWER -40C / MULTI-C |
62 - GGMEADOWWOODB0 | 62 - "EAGLEOWL / PROD. ADAPT. CIRCUI |
63 - 99A2A0 SRJR5 | 63 - "EAGLEOWL / PROD. ADAPT. CIRCUI |
64 - 99A202 SRJQR | 64 - "EAGLEOWL / PROD. ADAPT. CIRCUI |
65 - 99A200 QV38 | 65 - "EAGLEOWL / PROD. ADAPT. CIRCUI |
66 - 99AFH9 | 66 - "EAGLEOWL / PROD. ADAPT. CIRCUI |
67 - SSDSCKKB960G801 | 67 - "FLASH DISK DRIVE/ SSD 800GB T |
68 - WGI210IT SLJXS #925133 | 68 - "ETHERNET CONTROLLER.I210-IT. |
69 - JL82599ES SR1VN #934600 | 69 - "MICROCIRCUIT/10GIGABIT ETHERNE |
Hello Satyajeet,
I could see that we have created another post with the same information, please kindly refer to that thread for more updates on this behavior.
In this case, we will proceed to close this thread to avoid duplication of effort and the support will continue through the other post.
Deivid A.
