I have t7300 cpu socket p (ppga478) installed in my acer 4920g laptop. I want to upgrade/replace the cpu. I have checked that t9500 cpu may fit my laptop, i mean bios support it. My question is should i only buy the slaqh version (ppga478) or also the slayx version (pga478) may fit it/work ? Because the slayx version is very easy to find and slaqh very hard to find. thanks in advance
Your first step is getting the information from Asus, they will let you know if the Spec code SLAYX is compatible with your motherboard.
