Hello, I recently replaced an old i5-4570 3.2Ghz(Turbo 3.6Ghz) with a bit better i7-4790k 4Ghz(Turbo 4.4Ghz) cpu, it works fine I hope, but I noticed that Task manager shows my base speed is 3.2Ghz and it never goes over, even though at the top it says 4790k 4Ghz, is it just a bug? or does my cpu has problems?
I didint change any settings, just swapped the cpu.
Should I check something in the BIOS?
Hello Mociute,
Thank you for posting on the Intel* Community.
To better assist you, please provide us with the below information:
- Are you having performance issues? (please provide details)
- Do you have all the cores active?
- Can you please provide a screenshot of your power settings in Windows*?
Provide the below reports:
Intel® System Support Utility (Intel® SSU)
- Download the Intel SSU https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
- Open the application and select "Everything" click on "Scan" to see the system and device information. By default, Intel® SSU will take you to the "Summary View".
- Click on the menu where it says "Summary" to change to "Detailed View".
- To save your scan, click on "Next", then "Save".
Run the Intel
Maria R.
Hello Mociute,
Let me know if you need more assistance.
Maria R.
Hello Mociute,
Maria R.
