Hi, sorry for my bad english .
I have a little overheating situation. I use i7 4790K on Asus Z97 Pro Gamer, case Zalman Z3 Plus with very good air flow. I recently bought Gelid Tranquillo rev3 as cooler, but temperatures were 35-40 idle, 60-65°C slightly working and up to 75°C in full load.
Now I installed Noctua D15, reinstall thermal compound twice and my best results are 27-32°C idle, 40-65°C medium work load and 68-75°C in full load. But in prime up to 100°C in just one second.
My PCH on MB is up to 48°C. Is that normal? It did not matter which application method of thermal compound or number of coolers i used. (I use MX4 paste.)
Thank you in advance for any hints!
High temperature with an Intel® processor i7-4790k was previously reported and it seemed to be an issue with motherboard BIOS, please check the link below for instructions about this matter:
/thread/54032 https://communities.intel.com/thread/54032
Allan.
Did you check the thread about the processor temperature on the Intel® i7-4790K?
Allan.
![](/skins/images/45C6C2D737ED71F4C51F0145C8CB1E9C/responsive_peak/images/icon_anonymous_message.png)
