Hello friends,
I recently built an ITX pc with a 14600k and a NH-L9x65 Cooler. Even with a manual 0.05 - 0.1 mV undervolt through the BIOS I am hitting 90 - 100c, in CPU demanding games. I am stumped. I have pushed the undervolt to even 0.15 mV and the system stayed somewhat stable. This fixed the incredibly high temperatures, but the frametimes and 1% lows seemed to grow further apart, therefore leading to aggressive stuttering even with temps 65 - 80c. The GPU is a stock 4070 Super so there is zero issues with temperatures. I am aware that my cooler is not the best option for this specific build but it should not be hitting 100c consistently even with an undervolt. In the meantime I will remount the cooler and apply new reputable brand thermal paste. I would also like to add that my cpu fan is running at 100% during all of this. All the undervolting has been done through the BIOS, and all I have changed is the "Actual VRM Core Voltage" to offset mode and adjusted the negative undervolt accordingly. I will link a video to the BIOS settings tutorial I used. The only settings that were changed from default are the Offset Mode on the Actual VRM Core Voltage and the XMP Profile for my memory. If you have any questions or want me to run any tests feel free to ask!
Cheers
Kanerator
Hello Cannerator,
I tried to check the specification of your NH-L9x65 Cooler and found out that this is a low profile compact processor fan.
This cooler as per their website is not for processor that generates high heat loads.
https://noctua.at/en/products/cpu-cooler-retail/nh-l9x65/specification
I also checked the compatibility of Core i5-14600K and NH-L9X65 on their website and found that it has low compatibility.
https://ncc.noctua.at/coolers/NH-L9x65-19/cpu/all?q=i514600k
If you are having this issue since the integration, try using a different and CPU cooler for high heat generating processors like Intel's "K" processors. To further check the information above, you can also contact the manufacturer of the processor cooler.
Michael L.
Hello Cannerator,
Michael L.
Hello Cannerator,
I am sending another follow up to check and hoping that you are now talking to the manufacturer of the cooler.
Michael L.
