<!--[if gte mso 9]> Normal 0 21 false false false MicrosoftInternetExplorer4 <![endif]--><!--[if gte mso 9]> <![endif]--><!-- /* Style Definitions */ p.MsoNormal, li.MsoNormal, div.MsoNormal {mso-style-parent:""; margin:0cm; margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:12.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} @page Section1 {size:595.3pt 841.9pt; margin:70.85pt 70.85pt 70.85pt 70.85pt; mso-header-margin:35.4pt; mso-footer-margin:35.4pt; mso-paper-source:0;} div.Section1 {page:Section1;} --><!--[if gte mso 10]> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Normální tabulka"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:# 0400; mso-fareast-language:# 0400; mso-bidi-language:# 0400;} <![endif]-->
I have in my laptop Asus F3Sr intel core 2 duo mobile processors T5450,Socket PGA478.
I want upgrade my procesor and i buy intel core 2 duo mobile processors T5600.
These two processors supports Socket PGA478. the second processor T5600 doesn't go apply onto Socket.Why?In specifications is supported Socket PBGA479, PPGA478.
How can I finds which processors can I use to Upgrade my Laptop?
- Tags:
- CPU
- Upgrade PC
The T5450 is uFCPGA (Socket P) and the T5600 is uFCPGA (Socket M) according to the infomation at http://ark.intel.com/ http://ark.intel.com/
The T5550 is the Socket P version of the T5600, from the above website.
