I want my Surface Pro 3 i7 to heat less and produce less noise
So I decided to lower TDP and multipliers
But if I change anything, any parameter at least to 1 point, then unplug a power my Surface Pro 3 immediately resets!
What is the problem???
You can only modify CPU values on systems that allow such modifications in the system BIOS; these systems usually include unlocked Intel® Core processors.
Please check with the system manufacturer if you have questions about the BIOS setup.
![](/skins/images/B7BA37F9CE4B52FF7CAE1FB0388839C8/responsive_peak/images/icon_anonymous_message.png)
