Dear all,
This is Muhilan Veerarasu from India. I have tried to establish one 64-bit kernel at the booting end using CDs/DVDs. I caught all the required exceptions. However PC restarted when i had booted my CD. I used Dual core intel processors. What is the problem and how can i overcome from this problem?
Kindly reply me as soon as possible.
Thanking you.
This does not sound like an Intel problem, but rather a Microsoft problem. Contact Microsoft support.
Doc
This is not the microsoft problem. This is my own kernel based on intel platform. Tell me the factors for PC restart problems when 64-bit kernel is tried to establish even though all exceptions were handled? If you are interested, I am ready to forward my assembler source to you.
Thanking you
Muhilan Veerarasu
Your own kernel, eh? Well, you are simply not supported by microsoft or intel. I do not think you can even get help from the linux community.
Keep the assembler. We do not do that here.
Doc
Dear all,
I programmed PMC Controller to move PC to S5 soft-off state in 8-series PCH motherboard. From Intel PCH 100-series onwards, It has been moved to new PCI Bus#. Just i had captured ACPI Base address and had moved PC to S5 Soft-off state. Can i do the same for PMC Controller from 100-series onwards. PMC Controller is located at PCI Bus 0,Device 31 Function 2. Upto 8-series PCH, PMC Controller is located at PCI Bus 0,Device 31 Function 0. Can i follow same procedure like in 8-series for PMC controller from 100-series onwards?
Kindly relpy and help me.
Dear Sir/Madam,
I already posted the same query in intel developer zone. however, I got no reply. i expect reply asap.
Thanking you
Muhilan Veerarasu
"i expect reply asap"
Yes, of course you do. And, to get that reply you must use the proper forum. We cannot help you in this forum, but you can get assistance in the Developer zone https://software.intel.com/en-us/home and https://software.intel.com/en-us/forum.
Continue to use the developer zone to get a response.
Doc
Dear all,
Tell me that in which intel developer zone forum i have to put this query to get response. I expect response asap.
Thanking you
Muhilan Veerarasu
