Processors
14674 Discussions
Why does task manager show an incorrect maximum speed of 1.8ghz when it should be 3.4ghz (intel core i5-8250u)?
Why does task manager list the maximum speed as 1.8ghz instead of 3.4 and also why is the cpu running less the minimum clock speed, 1.6ghz
n_scott_pearson
These are the numbers that TM has SEEN, not the true maximum that might be supported by the processor. As for a minimum, there is no minimum. Your processor, depending upon PM conditions, can be clocked down to 0MHz.
If you want more information on the workings of TM, talk to Microsoft.
