So, i downloaded recently Modern Warfare, the new one. My Pc specs are: Intel core i7 9700KF, nvidia geforce rtx 2080 super, 16 gb ram 2666mhz ddr4, motherboard MSi MAG Z390 TOMAHAWK, with liquid refrigeration. Everything in the game is fine, except the temperature of the cpu. All the graphic configuration are in ultra with 100-144fps. When i start playing the temperature goes up to 89,90,95 and then in 100 degrees. Sometimes it goes down again to 86 but goes up to 98-100 in a few seconds. This in not common with other games, just with this one.
Bios update needed
Incorrectly installed cooler
Inadequate ventilation
Improperly applied thermal paste
Incorrect Bios settings.
Doc
But if that were the case, this shoudn't be happening with other games too? I have games that require much more than this one (Modern Warfare) and i have no problem with them.
Are all other games consuming the same resources?
Check the items I listed.
Doc
![](/skins/images/1FC86CD46823E418D1E2B7B4DC10231C/responsive_peak/images/icon_anonymous_message.png)
Topic Options
