So i've got an i7-4770 processor and https://www.kingston.com/dataSheets/KVR16E11_8.pdf this ecc memory.
Processors manual says that ecc is not supported, but it is not clear if ecc funcionality is not supported or memory modules overall.
Will this memory module work as usual non ecc memory with this processor or PC just wont start. Also will I need ecc suported motherboard? Thanks
- Tags:
- ECC Memory
No, it won't work. You need to use non-ECC DIMMs.
