I have installed Windows 10 IOT 2021 Enterprise OS on our product and observed 'Yellow question marks in Device Manager' for the below devices.
'Base System Device'
'Multimedia Controller'
'Universal Serial Bus(USB)Controller'
'Unknown device'
I tried chipset driver but it didn't solve: https://www.intel.com/content/www/us/en/download/780252/intel-chipset-device-software-for-windows-10-64-bit-and-windows-10-iot-enterprise-for-intel-nuc-13-compute-element-elm13ib-x.html?wapkw=chipset
Could you help us to find the appropriate driver for the above issues?
Hello Xing_Mike1,
Thank you for posting on the Intel® communities. I am sorry to know that you are having issues with your Intel NUC.
1. What is the exact model of your Intel® NUC 13?
2. What is your Windows 10 version and build?
3. What is the IOS version installed?
4. Was the unit working before? When did the issue start?
Deivid A.
Thanks for your reply.
I am seeing yellow mark sign for the below devices in device manager. So my question is, I need appropriate intel drivers for these issues to fix.
1. Base System Device
2. Multimedia Controller
3. Network Controller
4. PCI Device
5. SM Bus Controller
6. Universal Serial Bus(USB) controller
7. Unknow Devices
So i need an help to find out the appropriate drivers for the above devices. Attached the image for more info.
Below are my system details:
Windows 10 version and build - Windows 10 2021(21H2)IOT Enterprise LTSC (OS Build 19044.3086)
Architecture: AMD64
processor: 12th Gen Intel(R) Core(TM) i7-1265UE 1.70 GHz
System Type: 64-bit operating system, x64-based processor
Hello Xing_Mike1,
Thanks for your response. In order to provide you with the proper drivers I will need the exact model of your Intel NUC.
Also, I noticed that you have the Windows version 19044 and the latest one is 19045. I recommend you update your Windows version, including the optional updates.
Deivid A.
How to get the model of Intel NUC?
Hello Xing_Mike1,
Thanks for your response. You can check the NUC model using the following steps:
- Open OS browser> type "MSinfo"> press "Enter"> check under "System Model"
Also, let me know if you were able to perform the Windows update.
Deivid A.
Hi Deivid,
Thanks for the response.
Below are the details:
OS Name: Microsoft Windows 10 IoT Enterprise LTSC
System Model: POC-421-12
System Type: x64-based PC
Processor: 12th Gen Intel(R) Core(TM) i7-1265UE, 1700 Mhz, 10 Core(s), 12 Logical Processor(s)
Yes with Windows Update some issues are fixed but i don't want to do that. As per my requirement i have to install the drivers manually.
Hello Xing_Mike1,
Thanks for the information provided. I was performing additional investigation and I would like to let you know that the NUC may not be compatible with Windows 10 IoT Enterprise LTSC. Microsoft provides all the drivers needed for the operating system to work and the driver from the computer manufacturer (Intel in this case) could not work properly.
If you are not having issues with the regular version of Windows 10, I recommend you check with Microsoft to get the right drivers for Windows 10 IoT Enterprise LTSC.
Please keep in mind that this thread will no longer be monitored by Intel.
Deivid A.
![](/skins/images/45C6C2D737ED71F4C51F0145C8CB1E9C/responsive_peak/images/icon_anonymous_message.png)
