- Marquer comme nouveau
- Marquer
- S'abonner
- Sourdine
- S'abonner au fil RSS
- Surligner
- Imprimer
That happens again after upgrading to this version. Previous version had this after I upgraded to it and after a while - suddenly started working.
How can you fix it in a way that doesn't require to wait an undefined time after upgrading where it's starts working?
Best,
Nitay
Lien copié
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi Nitay,
I need the following information to provide you a way to fix it the issue in a timely manner. Kindly provide the following:
1. How did you update the Intel XTU? Is it through the prompt from the application or did you uninstall the current software and installed the latest version from our download center website?
2. Did you make modifications in BIOS particularly on the P-Cores availability? Are all of your P-cores enabled?
3. It would really help us if we can get more information about your system. Please download and run our Intel® System Support Utility from this page. To run it, please press "Scan". After the scan is finished, click next and there will be a save button, giving you an option to save the logs to a text file, please do so and attach the file on your reply. You can refer to How to get the Intel® System Support Utility Logs on Windows* for instructions.
Looking forward to your post.
Alfred S
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
1. Through prompt.
2. No.
3. I'm not going to go through this process again, this has happneded with the previous version until you've resolved it (you can check how you did that....) I went back to version and it works flawlessly.
Obviously in every new version - you don't support my CPU 13600k for some reason and after a few weeks this option is again available with no change in my configuration or updating the application. Check with your engineers how it was resovled for the previous version - I imagine same should be for the new one.
Here'e a screenshot with the previous version I just rollback to where it's available.
Kinda ridicilous from a customer stand-point to update to a newer version and have it not support my CPU for a few weeks.
Best
Nitay
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi Nitay,
Thank you for your response.
First and foremost, we are humbly sorry that you have been experiencing this recurring issue every time you upgrade and I agree with your point that this should not happen for a few weeks every time you update. Rest assured that we will look into the issue that you are facing.
Furthermore, I understand why you are reluctant to provide the logs. I am trying to obtain it to check if the procedure that is documented internally would be a viable solution to your concern. We However, since you answered two of the other questions, please try to do the following —some of which you have already tried, but we would appreciate your cooperation to still proceed:
1. Please uninstall the currently installed Intel XTU on the system and download the installer from the download center. Locate the folder of the installer and right click to run as administrator. Follow the prompts to install the software and restart afterwards. After restarting, check if the behavior can no longer be observed.
2. Should the issue persist, kindly contact your motherboard manufacturer to ensure that your BIOS is up-to-date, and settings are reset to defaults.
We would appreciate it if you let us know of the results of the above procedures.
Alfred S
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi Nitay,
While waiting for the update of our recommendations, we think ahead if the suggestion did not solve the issue, we sent an email to ask for additional information, so we can investigate this behavior.
I will send you an e-mail to the e-mail address associated with your community profile regarding this, please check it out.
Alfred S
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi Nitay,
I wanted to check if you had the chance to read the email that we sent. Please let me know at your earliest convenience so that we can determine the best course of action to resolve this matter.
Alfred S
- Marquer
- S'abonner
- Sourdine
- Surligner
- Imprimer
Hi Nitay,
We need to close this thread since we have not gotten a response from you: maybe because you are busy or preoccupied at the moment. We know that this is important for you to get it resolved and it is also equally important for us to give you the right solution; as much as we would like to assist you, we need to close it to attend to other customers.
Should our suggestion not work, please also consult your motherboard manufacturer to check if they have an Intel Extreme Tuning Utility Software on their download website —that version may be the most compatible for your system.
We hope for your consideration and understanding on this one.
If you need any additional information, please submit a new question as this thread will no longer being monitored.
Thank you for contacting Intel® and have a great week!
Alfred S
- Marquer le sujet comme lu
- Marquer
- S'abonner
- Page imprimable
