Processors
14649 Discussions
Xeon E3-1231v
MMaho1
I have a Xeon E3 1231 v3 (with stock cooler) and was checking the temps during video encoding See pic > http://i.imgur.com/8M5VUvD.jpg . During web browsing the temps are under 40°C , room temperature is around 26°C. Should I be thinking of upgrading the stock cooler? ty
Hello, Majmuin:
I believe that is not necessary since your processor is behaving as expected. Bear in mind that you will have peaks whenever the workload is too heavy; however, based on the information provided your system is working fine. The TCASE temperature for your processor is 73.0 °C as long as you stay under that parameter your system will be fine.
For further reference visit http://www.intel.com/content/www/us/en/processors/xeon/xeon-e3-1200v3-vol-1-datasheet.html Intel® Xeon® Processor E3-1200 v3 Family: Datasheet, Vol. 1.
Amy.
MMaho1
But if u saw the pic the temps on some cores are reaching almost 100°C and since i do a lot of long video encoding im kinda scared the cpu wont last long
What happens when you are not video encoding? Do they stay on the same temperature?
Amy.
MMaho1
At idle the cpu downclockes to 700mhz and the temps at that time are 33-34°C. During web browsing- 8/9 tabs open i get like 40-45°C. I've already replaced the stock cooler with the Hyper Evo 212 and the temps are much, much better. 55-56°C max during 30min video encoding.
thanks anyways
cheers
Good news, I am glad that to hear that the cooler is working.
If you need further assistance let us know.
Amy.
