Hi there,
Six months ago I upgraded one of our HP ProLiant ML10 servers by replacing the original Pentium with a Xeon E3 1275 v5 (the motherboard supports both processors)
I now want to upgrade another of our HP ProLiant ML10 servers, but noticed that the Xeon E3 1275 v5 is no longer available.
I would like to know if I could use a Xeon E3 1275 v6 instead. The specs are almost identical.
Any thoughts?
Kind regards
Stephen
Hello shudson
Thank you for contacting Intel Technical Support,
We received your inquiry and I understand that you are looking for processors information/comparability. Please accept our apologies for any inconvenience this may be causing. We will be more than happy looking for a solution.
Upon rewiring the information you provided. We want to share with you that the Intel® Xeon® Processor E3-1275 v5 is still on lunched status you can review that in this link https://ark.intel.com/compare/88177,97478 https://ark.intel.com/compare/88177,97478, also on that same link you will see a comparison between the Intel® Xeon® Processor E3-1275 v5 and the Intel® Xeon® Processor E3 v6.
For information on distributors these links can help you locate them:
https://locate.intel.com/ https://locate.intel.com/
https://www.intel.com/content/www/us/en/partner/where-to-buy/overview.html https://www.intel.com/content/www/us/en/partner/where-to-buy/overview.html
In addition is important to take into consideration if the HP ProLiant ML10 is comparable with Intel® Xeon® Processor E3 v6, we advise to contact the manufacturer to get that information
Leonardo C.
I would add that you should also check with HP to ensure that the BIOS has support for the newer processor variants.
![](/skins/images/05D335160E7CD666F354185C812BA28D/responsive_peak/images/icon_anonymous_message.png)
